Saginaw conversion HP line
Old May 18, 2016 | 02:09 PM
wrdabney's Avatar
wrdabney
I have a saginaw PS pump and bracket in transit from ebay but the high pressure line from it was no good. I found an old thread where the high pressure line in the link below from Autozone worked as a replacement. I've also read that the existing F150 line worked for someone. There seems to be some conflicting accounts on this line. Can anyone who has done this conversion and had to get a new line or use the existing one tell me for sure? Thanks.
Duralast/Power Steering Pressure Line Hose 71079- ReadReviews onDuralast #71079
Old May 18, 2016 | 03:14 PM
GuitarJesus's Avatar
GuitarJesus
The high pressure hose fitting is different, you'd need one from an econoline, or take your original hose to an auto parts place that does hydraulic hoses, and show them what you need. My local CarQuest made them on the spot for another vehicle
Old May 18, 2016 | 04:04 PM
ArdWrknTrk's Avatar
ArdWrknTrk
pedant
The old Cardone 'upgrade' pump that is NLA used a hose from a 1977 F250 4x4.
I ordered it in, it was wrong....
I then used the van I got my pump from to order a new hose ($17!) and bent it around to fit my steering box.
Zorfox
Sep 25, 2010 05:40 PM
rpol7966
Feb 25, 2010 11:36 AM
WILDMAN_Stroker*7.3
Aug 2, 2009 10:37 AM
76and92ford
Dec 25, 2005 12:29 AM
