Tune up questions
Old May 18, 2016 | 12:38 PM
Cameo 57's Avatar
Cameo 57
Tune up questions
I am looking for some tune-up settings for my 94 idi turbo.
7.3IDIT/E40D/F350 RWD
The injector pump, and turbo with upgraded compressor wheel was supplied by Russ aka sandeater1. My transmission was recently rebuilt with a billet converter, and shift kit, and every component that could be upgraded, was. My tach sensor, and FIPL sensor have been replaced. I have installed head studs, and a 3" down pipe, connected to 3" straight pipe exiting behind the passenger rear tire. I adjusted the timing by ear and then took it to a local automotive shop and they said timing was at 10 BTDC, but they have not touched an idi in years and didn't sound confident.
I am running an electric fuel pump off a 6.5 GM and I am showing 5-8 psi at the IP throughout the throttle range, so I don't believe the IP is starving. Man does it start easy!
I adjusted the FIPL before towing my 5th wheel (approx 11,000 lbs) home this weekend, seemed to pull ok, EGT's got as high as 10-1100F, probe is installed between 5 and 7 exhaust ports.
I turned the IP up 2 flats and pulled the trailer back to storage and it seemed to really lug, exhaust temps were higher, and so were water temps. I didn't let it go over 1100, by just letting off the throttle. max speed on the 2nd trip was 55mph under load. I may have knocked the FIPL sensor, and I will check that.
It is running ok, but not what I am hoping for.
I see no black smoke from the exhaust when empty or pulling. not that I want to see black smoke, as Gale Banks says, that's just a waste, but I don't want this thing running too lean either.
What should the timing be set at? How can I tell if I need the IP adjusted up or down? How do I set the waste gate??
Thanks for the help.
Old May 18, 2016 | 03:20 PM
Leroy Unlisted's Avatar
Leroy Unlisted
can't never run a diesel too lean ..
Lean doesn't hurt a diesel like it do es on gassers ..
You want as much fuel as your air volume and flow can burn ..
Anymore is wasting gas/smoke/heat ..
Sounds like you're on the right track ..
go lean until you lose power and just keep tinkerin' with the timing ..
I donno about setting the wastegate ..
Sounds like a nice motor ..
Old May 19, 2016 | 11:10 AM
Cameo 57's Avatar
Cameo 57
Tested my FIPL Senssor and it is at 1.1-->4.2 so I'm happy with that. I'm going to turn the fuel back 2 flats, and take the 5th wheel for a cruise down the hiway and see how it goes.
Based on the Banks sidewinder instructions, 1050 is the "Safe max" you want to see on the pyro. No, I don't have a sidewinder, just looking for any data to use as a guideline.
Where should I have my timing at?
Old May 19, 2016 | 11:21 AM
PlumCrazy7's Avatar
PlumCrazy7
Most turbo engines are around 6*. If you don't have black smoke don't bother turning down the fuel.
Old May 19, 2016 | 11:24 AM
Cameo 57's Avatar
Cameo 57
the EGT temp is why I feel I need to turn the fuel down. Maybe the timing is where I need to look. If I could only find someone around here that has the Ferret tool and doesn't give the deer in the headlights look when you say non-powerstroke 7.3
Old May 19, 2016 | 11:29 AM
PlumCrazy7's Avatar
PlumCrazy7
Timing will help your egts. I simply wouldn't want to turn it down, adjust timing, then turn it back up. If you are being mindful of it, you will be fine with your egt temps.
slideman1955
Nov 23, 2017 09:14 PM
F250IH
27
Nov 1, 2014 03:52 PM
89IHDiesel
Aug 26, 2014 04:46 PM
whiteboyslo
Jul 10, 2012 09:58 AM
Tom D
Dec 26, 2010 02:18 PM
