I installed a Banks Sidewinder and turned the IP up (rich) 2 1/2 clicks. The only time I get any smoke out the exhaust is when I jump on it and the turbo hasn't "spooled up" yet. The engine starts and runs excellent. I also installed new injectors. I never timed it after the install. I average around 12 mpg in the city and around 15-17 on the road empty. If I hook a load onto it, the road mileage drops to 10mpg. I'm wondering if I increase the IP and change the timing will my (1) mileage increase or (2) will I get any more power. My EGT runs about 600-650 at 60 mph.
Appreciate any posts.
Tom
I did almost the same exact thing recently, too. Put a banks sidewinder on her, some new injectors and I still haven't had engine timed. I turned up IP 1.5 flats and no black smoke yet. I think you might want to turn fuel down a little because my EGT's are at 450 at about 60mph. I'm just saying, if you run her rich and then tow something, you could really overheat your engine (melt pistons, etc.).
so i would likely try using 7.5 - 8.0 BTDC (for the pulse method) since the book claimed 8.5 BTDC,and there where no turbo's at the time,thus no need for such an extra amount of fuel.so retarding the timing after a turbo install will likely add more performance according to the results posted there.
i see some guys pushing 9 and even 9.5 BTDC on turbocharged engines! not sure what they're thinking there.they're going the wrong way. im surprised they don't complain about turbo lag.
Thinking about my last post, I gave you wrong information. I believe my EGT's are about 650 at 60-65 PULLING MY 5TH WHEEL TRAILER.
The reason I settled on 2 1/2 clicks on the IP is, I was following instructions from one of our forum contributers. If I remember correctly, he stated he turned it up till he got just a slight amount of smoke on accelaration. I don't even get that. I have NEVER had the EGT over 1000 deg and that was climbing a LONG hill in the Rockies with my trailer. The Banks instructions state "1250 max"
I don't know how to incorporate two or more posts into my post so please read my next post.
Thank you for your reply
Tom D
Thanks for the very interesting reading. Sounds like I'm going to have to find a diesel mechanic with a timing meter as they sound like they are as scarce as hen's teeth. I won't dare try "ear timing" it. It runs super now but I don't know if I am getting optimum performance out of it. I'm not crazy about the mileage (12 in town. 15 on road empty. 10 on road with ANY size load) I have been running 100% bio for the last year. Since owning this truck, I have added a Banks Turbo, ram air, new injectors. I have never adjusted the timing and I have logged approx 80,000 miles on it. I now know I should have been more attentive to the timing. I try to take good care of my engine but it seems I have failed to do so. Any help with this timing issue will be greatly appreciated.
Tom D
One thing comes into play here, where is your thermocouple located?
After the turbo, 950 is your max EGT.
Pre turbo, 1250 is your max EGT.
On a very long pull, you should drop either number by 50 to 100 degrees.
Mine is ahead of the turbo. I don't know whether I should turn back the IP to attempt to get better mpg or what. Since I never timed it, I better find someone who can do it for me. It sounds like the "ear" method is not the safest way to do it. What are your thoughts?
Getting plenty of snow to push this winter?
Thanks Dave
Tom D
I run somewhere around 9.5 or 10 degrees advanced, by the ear method.
If I run less, the power and boost just is not there.
Then again, since I am not exactly stock, several things are different for me.
Out plowing this morning at 3 AM, 15 degrees and 1150 was easy to get driving between jobs on the hills.
My thermocouple would be sticking in the #8 exhaust port if it were a little longer.
The way my engine runs when it is cold, I really need to figure out how to get an intercooler in there.
