Pulling EFI 302
Old May 19, 2016 | 08:17 AM
Scndsin's Avatar
Scndsin
Originally Posted by 1994 302
...now can someone please tell me everything he will need to get so I can drop my explorer motor in my truck
I'm sorry to be harsh, but:
Everything from the condenser back to the firewall + computer + crossmember + exhaust manifolds + linkages + distributor + intake + oil pan(?)
Don't cut any wires.
Get all the fasteners.
In short, everything for a 94 F-150 V8 but the long block.
Old May 19, 2016 | 01:13 PM
1994 302's Avatar
1994 302
Okay so if I get a truck with a 5.0 does it have to be a 94? And the if so why?
Old May 19, 2016 | 01:48 PM
GoinBoarding's Avatar
GoinBoarding
Why not use a MAF coversion for a truck on the explorer long block? Gain a working engine with better heads, and wont have to scratch your head trying to wire it up. That should be able to "adapt" to the increased air flow just the same as when guys put better heads on a truck 302.
Am I missing something?
Old May 19, 2016 | 02:06 PM
Scndsin's Avatar
Scndsin
... And the if so why?
Anything after 92 would be best, older than 95... well, depends.
94 is a division year in wiring & computer control of the transmission & the trans itself. (Which was asked about a few posts ago & we still don't know)
You asked about "drop in" which is a big difference "can be adapted, made to work, etc."
Anything can be made to work. All it takes is time, money, skill, mechanical knowledge, tools, parts, materials, documentation, work space, drive, will & dedication. When you start to subtract any of those individual items, the chances of success goes down proportionally with each one removed.
Old May 19, 2016 | 03:28 PM
rla2005's Avatar
rla2005
A wiring harness from a 1994 F150 would be the best choice because it already matches the model year of your truck. Ford was notorious for changing wiring from year to year. If you try anything before or after 1994 you MAY run into minor wiring changes to get everything to work between the engine/cab/computer.
To further complicate things Ford started using Mass Airflow Flow (MAF) mid-year 1994. So if your current truck is a Speed Density version, most likely, that narrows down the "easy" swap to an early 1994 with Speed Density.
Old May 19, 2016 | 03:49 PM
bashby's Avatar
bashby
If you are going through all the trouble why not get a 351?
Old May 19, 2016 | 03:54 PM
1994 302's Avatar
1994 302
I already have the 302 but I might pick up a 351 and go that route instead he's asking $500 for it with the harness it's efi around 93-96 he's gonna try finding the year on it
Old May 19, 2016 | 05:16 PM
luv2fly's Avatar
luv2fly
I was going to look into this for my '88. Explorer 5.0 slide in a B303 cam and have fun.
Screw this. I'm rebuilding a hot-rodded 302 I've had for years and keeping the carb.
Good luck with this build. I'll be watching how it pans out. Hope you change my mind!
0ldman
Apr 7, 2015 05:33 PM
OK F1
Jan 28, 2013 09:22 AM
darylcrutch
28
Mar 29, 2009 08:38 PM
BART M
Mar 21, 2003 02:15 AM
Superdave
Jan 11, 2000 09:35 AM
