Excursion having some idle issues.
Old May 17, 2016 | 04:12 PM
ROBBINthaHOOD's Avatar
ROBBINthaHOOD
My 2001 V10 has started having some really rough idling issues.Hooked up IDS and at first it gave an iac circuit error but that went away but p1131 and p1151 keep popping up and also getting an egr flow error and maf contamination error. Where should I start? The idle will actually almost cause the engine to stall and sometimes it will surge to around 1100 rpms and then back down to 700 or so. As far as driving down the road it drives fine just at idle it acts up. Thanks guys.
Old May 17, 2016 | 04:43 PM
LivingLarge's Avatar
LivingLarge
IAC valve...... First place I'd start
Old May 17, 2016 | 08:33 PM
WE3ZS's Avatar
WE3ZS
I agree with Michael, IAC valve sounds like its dirty.
Does your V-10 have an EGR?
Old May 18, 2016 | 02:18 AM
ROBBINthaHOOD
Im not sure if it has an EGR or not. I will do some looking around on it tomorrow and see. I will have to pull the IAC and clean it and see if that helps and if not Ill just replace it and go from there. Just trying to check the simple stuff first. Thanks for the input.
Old May 18, 2016 | 07:06 AM
Bently_Coop's Avatar
Bently_Coop
On the drivers side exhaust manifold do you have a hose or a capped boss? If you have a hose that is the EGR system.
Before removing the IAC run some seafoam or berrymans b12 through the brake booster hose. Tons of youtube videos to show how this works. If your idle clears up you will know it is the IACV. Mine cleared up for a couple weeks and I eventually replaced it because the same issues were returning.
Old May 20, 2016 | 07:12 PM
ROBBINthaHOOD
Changed the IAC out and now I find the elbow on the pcv valve busted. Anyone have a part number? Thanks.
Old May 21, 2016 | 01:41 PM
ROBBINthaHOOD
It's the elbow that goes on the throttle body housing. Is .750 on the large end and .375 on the small end.
Old May 21, 2016 | 09:55 PM
Bently_Coop
https://www.rockauto.com/en/moreinfo...372351&jsn=429
Old May 23, 2016 | 11:24 AM
ROBBINthaHOOD
Its the hose in the middle of the pic. I temporarily have a sparkplug boot on it and its semi working, its loose still on the large end but the vaccuum holds it on, need to put a clamp on it. I need the correct hose tho. Thanks.
Rob_82
Feb 11, 2016 10:31 PM
Ford-F150-88
Jul 12, 2010 11:55 AM
cathcart72
1983 - 2012 Ranger & B-Series
May 17, 2006 06:14 PM
njf207
Jun 8, 2005 04:03 PM
flier
Modular V10 (6.8l)
Jul 16, 2003 10:21 AM
