8BA Engine rebuild..My first time
So now that I have all the sheet metal removed, repaired, primed and ready for paint, the chassis cleaned and painted..wife reupholstered bench seat, and interior as needed, new brakes, wheel and master brake cylinders, shocks, brake lines, rear end inspected, cleaned and ready to go, transmission awaiting some advice from Van Pelt as some here have suggested and the steering gear rebuilt..pheww! (Found a nice guy in CA who had a sector shaft for me)
I've got the intake manifold and heads and water pumps in my cleaning bucket soaking and degreasing..ordered new carb. So having said all this and not necessarily in the order I described, do I remove the cylinders from the camshaft and out of the block? Followed by removing the camshaft followed by removing the intake and exhaust valve assemblies?? What parts (other than those worn or damaged) should be replaced consistent with routine maintenance like removing crud, rust etc. from engine block etc.
I would appreciate some thoughts..shop manual doesn't give any order of these sort of things.
Order of disassembly is:
-- remove ridge on cylinders
-- remove oil pan and oil pump
-- remove piston/connecting rod assemblies
-- remove main bearing caps
-- remove crankshaft
-- remove valve assemblies
-- remove lifters
-- remove timing cover
-- remove camshaft
Your engine stand doesn't look real sturdy, be careful when flipping the engine over!
I want engine clean and running at normal temperatures and normal oil pressure.
You could also measure the bore diameter to determine piston size.
example all gaskets, set of pistons & rings rod & mains melling oil pump
cam bearings all for around $850. Then valve stuff local Napa.
Go the extra mile and weigh all pistons and rods check crank balance and
balance complete flywheel with pressure plate & disk. Easy tip, first thing
install cam bearings then cam do all the valves then adjust valve lash with only
the cam gear to turn by hand because with no crank you can see the heal of
the cam. Maybe over kill but we have an adaptor to spin the cam with a drill
then recheck valve lash as though the engine is running I guarantee it will be
whisper quiet and smooth as silk. thats what we want....
One thing for sure, I'm going to get this engine to run before reinstalling in case I screw somethings up. I'll keep you posted and will probably looking for help along the way.
Thanks to all of you.
The manual tells you how to measure piston fit in the cylinders using a feeler gauge, if you don't have the tools to measure. If budget is that big a concern, then a hone and re-ring should do well. I'm not seeing anything to indicate the engine was in bad shape, what were the specific problems?
The crankshaft has sludge traps in the throws. To clean them you have to pull the plugs and thoroughly clean out the oil passages. The replace the plugs with new ones. It would be worth it in my opinion to take at least the block, crank, and heads to a shop to be vatted, measured, and checked for cracks.
What do the bearing shells say on the back side?
55F350, you can check yours thru the spark plug holes with a borescope, or if you have good eyes. I wouldn't assume a 52 would have them because it likely has rotators. Mine is an EAB block, so 52-53, and it didn't have them
Ross says the manual describes how to check them with gauges so I would start there and wait to make sure you don't need to have it bored and go up a size before you start buying parts.
The method in the manual is honestly BS in my opinion. A machine shop can mike them in 10 minutes and give you much better information. In particular the manual's method doesn't tell you much about taper. I ran my engine with .010" taper for 7 years, and it ran well enough. A bore, new pistons and rings would run about $400. You also have the option to go back with 3-ring pistons, with less drag = "free" HP.
Early Ford V8 Regional Club List
Not all local machine shops or engine builders know flathead engines. Most clubs have local club members who have built engines. If you strike out with the EFV8 club try posting for help on the fordbarn.com. To find someone near you.
Always nice to have folks looking over your shoulder to guide you with a first time build. They will usu. be willing to loan you the specific tools to help you through this part of your restoration.
I just finished my rebuild and sought out a lot of help. Send me a pm and I will share some of the pitfalls and successes I made with Mater.
Your engine looks pretty fresh but as has been stated measuring your components is critical. Next is setting a goal that is within your budget.
Two thumbs up on balancing your rotating assembly. Ford did this but subsequent rebuilders would not have.....$$ well spent.
