Sponsored by: Real Truck
Sound system help
Old May 17, 2016 | 03:09 PM
79Ranger250's Avatar
79Ranger250
Sound system help
I have a 2012 f250 xlt, with the xlt premium package. And I've got 2 JL 10s, in shallow truck boxes, and an amp sitting around, and was curious as to how difficult it would be to hook them up in my superduty.
Old May 17, 2016 | 10:56 PM
Boaterguy's Avatar
Boaterguy
Factory radio? They don't have the pre amp out plugs for an amp. So, in order for you to do it, your amp will need to have the high impedance inputs to work. In simpler terms, newer amps have 2 ways to input the signal from the radio. The RCA plugs are low impedance and the high impedance plug you tap injto the speaker wires for the signal and it should work just fine. If your amp has it, it should be labeled as such.
Old May 18, 2016 | 06:39 AM
RightWingNutJob's Avatar
RightWingNutJob
If your Amp doesn't have speaker level inputs, then buy a speaker to pre-amp line-level-converter.
Speaker to Line Level Converter
Here's a selection:
http://www.amazon.com/s/?ie=UTF8&key...l_54dfqbc3la_e
They run from simple to fancy. This one can control a subwoofer
Amazon.com: AudioControl LC2I 2-Channel Line Out Converter and Subwoofer Control: Cell Phones & Accessories Amazon.com: AudioControl LC2I 2-Channel Line Out Converter and Subwoofer Control: Cell Phones & Accessories
dono
May 30, 2007 12:00 AM
Ervin
Dec 31, 2004 10:15 PM
soksniffer
Sep 17, 2003 01:21 PM
stu69
Sep 2, 2003 09:21 AM
brutusbux
Aug 15, 2003 07:28 AM
