Sponsored by: Innova
2001 Excursion-Add amp & sub
Old Aug 14, 2003 | 09:24 PM
brutusbux's Avatar
brutusbux
Question 2001 Excursion-Add amp & sub
I was thinking of adding an amp/sub to the factory system. Does the factory CD6 have RCA outputs or do I need to use speaker level inputs? I would like to keep the factory radio. Any suggestions are greatly appreciated.
Thanks!!!
Old Aug 15, 2003 | 07:28 AM
PrPlayboy's Avatar
PrPlayboy
No it does not. You will need to get a Line Output Converter. Make sure you get an amp that has a bass or gain control **** because that is the only way you will be able to control the bass output.
