52 armrest & dome light
Old May 17, 2016 | 01:04 PM
tractormanbill's Avatar
tractormanbill
tractorman
I decided to put my dome light on the back under the rear window in between the seat backs.
It is so tight in the cab I decided to use an arm rest with only one cup holder built out of thick wall square tubing with wood top. May add another for the passinger on the right kick-wall some day.
TractormanBill
Old May 17, 2016 | 01:17 PM
Scotty's 52 F3's Avatar
Scotty's 52 F3
That came out nice!
Old May 17, 2016 | 01:20 PM
tractormanbill
tractorman
Thanks, the arm rest stand is covered in black.
I just could not figure out how to hang the light on the top using an ABS headliner.
TractormanBill
Old May 17, 2016 | 02:49 PM
ALBUQ F-1's Avatar
ALBUQ F-1
Looks nice Bill! For upper-level lights I went with a GM rear-view mirror that has lights built in. I imagine your light's location will do a pretty good job.
Old May 17, 2016 | 08:58 PM
underthebridgejim's Avatar
underthebridgejim
FTE fan
Beautiful job on the cab Bill. The fuel tank sharing the same color scheme along with the SS trim, really makes it look super clean. I like it.
Old May 18, 2016 | 06:08 AM
GreatNorthWoods's Avatar
GreatNorthWoods
Nice job!
Old May 18, 2016 | 06:44 AM
49willard's Avatar
49willard
TractormanBill
Bill, I added a donor Ford pickup truck overhead light working from the F-1 center cab roof screw receiver (the U shaped clip originally spot welded to the underside of the cab roof). I inserted a ground to a point screw in that hole and then fit up the ABS headliner and pushed it up to make a mark on the backside of the headliner. I then created a backing plate that accepted the donor truck light. I would not say that it was easy but not really all that difficult. Unfortunately I took no pictures.
What you did was certainly much easier.
03X
Jan 15, 2016 10:54 AM
49fordv8f4
Aug 3, 2015 08:29 PM
Drewski 2
Mar 2, 2009 02:41 PM
42nineranger
Sep 24, 2007 07:57 PM
