How to identify engine size
Old May 17, 2016 | 09:15 AM
dbyrd342's Avatar
dbyrd342
I recently got a 1968 ford f100 and the 4th digit in the VIN says Y for 360 but the owner says it was swapped out but he doesn't know what size. How can I identify my engine size?
Old May 17, 2016 | 10:03 AM
Coastal68's Avatar
Coastal68
Assuming it's another FE, just pull the #1 cylinder spark plug, find TDC and take a wood dowel, insert it into the plug hole until it hits the piston. Then mark the dowel where it touches the edge of the valve cover, rotate the crank until you have BDC, insert the dowel and mark it again. Measure between the marks to find your displacement.
A 360 will have a 3.5" stroke and a 390 will have a 3.784" stroke. If you come up with something other than these two strokes then it's time to do some digging and figure out whatcha got.
Did you buy the flat black truck?
Old May 17, 2016 | 10:43 AM
dbyrd342's Avatar
dbyrd342
Yea I did get that truck. I'll post a picture of the engine tomorrow
starbuck1971
Mar 25, 2015 09:41 PM
Oldfordf100
Sep 13, 2010 03:34 PM
erynod1
Aug 13, 2009 10:41 PM
Unwound
Apr 6, 2005 03:20 PM
ZombieSlayer
Apr 6, 2003 03:54 PM
