Trailer Brake Limit?
So, is there an additional adjustment I'm missing?
Note: Only perform this procedure in a traffic-free environment at speeds of approximately 20-25 mph (30-40 km/h). The gain setting sets the trailer brake controller for the specific towing condition. You should change the setting as towing conditions change. Changes to towing conditions include trailer load, vehicle load, road conditions and weather. The gain should be set to provide the maximum trailer braking assistance while making sure the trailer wheels do not lock when using the brakes. Locked trailer wheels may lead to trailer instability.
1. Make sure the trailer brakes are in good working condition, functioning normally and properly adjusted. See your trailer dealer if necessary.
2. Hook up the trailer and make the electrical connections according to the trailer manufacturer's instructions.
3. When you plug in a trailer with electric or electric-over-hydraulic brakes, a message confirming connection appears in the information display.
4. Use the gain adjustment (+ and -) buttons to increase or decrease the gain setting to the desired starting point. A gain setting of 6.0 is a good starting point for heavier loads.
5. In a traffic-free environment, tow the trailer on a dry, level surface at a speed of 20-25 mph (30-40 km/h) and squeeze the manual control lever completely.
6. If the trailer wheels lock up, indicated by squealing tires, reduce the gain setting. If the trailer wheels turn freely, increase the gain setting. Repeat Steps 5 and 6 until the gain setting is at a point just below trailer wheel lock-up. If towing a heavier trailer, trailer wheel lock-up may not be attainable even with the maximum gain setting of 10.
Procedure for Setting Trailer Brake Controller Mode Select the correct option using the information display. Choose electric for trailers with electromagentic drum brakes or EOH for trailers with electric over hydraulic brake systems. See Information Displays (page 108).
Trailer Brake Effort Setting The trailer brake controller allows the user to customize how aggressively the trailer brakes engage. The default value is "Low" and is the recommended setting for most trailers. If your trailer's brakes require more initial voltage, or if you prefer more aggressive trailer braking, then select either the "Medium" or the "High" setting.
selecting low, med, high will make a big difference. i know this sounds like i'm being a smart a$$, but go thru the information display to see what options are available to you on your truck and if you don't understand then go to the book.
And, I don't think you are being smart. You are answering the question that I asked, and I appreciate it.
The trailer brake effort setting isn't going to change anything for you. It doesn't change the maximum voltage to the brake circuit, it just changes how fast voltage ramps up as you press the pedal. With the gain to ten you're getting maximum voltage to the circuit, so how aggressively the controller ramps up with the pedal isn't going to affect wheel lockup with the hand brake.
At the time I only put brakes on one axle as that's all the trailer had initially. But, for under $200 I can put them on the other axle, and I think I'll do that before we tow 2000 miles round trip this fall. And especially so if the truck won't give me full braking.
Having said that, I wonder if the Tekonsha Prodigy 3 brake controller on Rusty hits the brakes harder initially, causing them to lock. If that's the case, might running the brake effort setting up on the new truck do the same? I get pretty good braking, but just not quite what I remember from Rusty.
For my own education, is being able to lock up the brakes an effective test? When we bought our last travel trailer (32', 9k lbs) the dealership just said dial it in until it feels like the truck isn't being pushed. Then do a brake check using just the trailer brakes to see if it can slow the truck down (at 5-10mph).
BTW - I'll send reps for testing and thinking about the brakes ahead of time. It's comical (unfortunately) counting the number of trailers on the side of the road on the Friday of a big spring weekend. Too many folks pull their trailer out, de-winterize it (boat, travel trailer, whatever), MAYBE check tire pressure and then haul azz to the weekend fun. Boat trailers are the worst... Nothing like introducing cold water to hot brakes and electrical systems to bust sheeeeet up.
I've never found an electric brake system that I thought was consistent. I've had electric brakes on three different trailers now, and I've always been surprised at how inconsistent they can be. One application and things come to a stop smoothly, but the next stop light they bite harder and lock up. For some reason it seems like most of them grab a bit harder at low speeds than high speeds. Just my impressions, never read any explanation for that.
If the braking performance is adequate and they are in adjustment I wouldn't worry about it. Unfortunately I think you're going to have problems with electric brakes in that application, but hopefully you'll prove me wrong.
Tom - I adjusted the brakes when I installed them, but haven't since I've put 100 miles on them. So, it is quite possible that they wore-in and now need to be re-adjusted. I'll do that this summer when I put brakes on the other axle, re-check the bearings, lights, tire pressures, etc as I get ready for the big trip. Thanks.
As for inconsistent performance, I've had surge brakes on several trailers, and have have very consistent performance - awful. I always seem to be buying used, and the brakes are as these were, rusted. One the ones I've repaired I got fair performance out of it, as it didn't seem to push the tow vehicle, but backing up was the pits. So, I have high hopes for these electric ones.
