2005 6L overheating
Old Oct 29, 2004 | 01:14 AM
tom in las vegas's Avatar
tom in las vegas
Question 2005 6L overheating
my new 05 6L powerstroke works great except when i pull a 16,000lb fifth wheel up steep grades the engine temp guage either goes just below or to the red and emediately i hear the fan clutch engage like a jet engine and the temp emediately drops to normal, this continues to cycle until i crest the hill, it never does this except for very steep hills and the trany temp stays at normal. ford says it wasnt overheating and they aware of the problem and they are working on a solution? anyone having this problem
Old Oct 29, 2004 | 01:29 AM
tbirdrick's Avatar
tbirdrick
seems ok to me
You are pulling max load up a steep hill, the temp goes up, the fan kicks in, the temp goes down. Sounds ok to me.
The one thing you might want to check is the temp guage, to see exactly how hot it is when it hits the red zone. It could be off a bit.
Does the trans temp go way up under these conditions??
Rick
PS: My 2005 is on order....how do you like the brake controller?
Old Oct 29, 2004 | 01:55 AM
tom in las vegas
thanks for the reply, the trany temp never moves at all, my worry is that if the gauge is correct and its hot enough to go into the red it is frying things like thermostats and sensors etc and not good for the engine, i asked ford why the fan clutch waits until its in the red to engage and they said the computer says its not actually overheating but they dont know how to make the fan clutch engage sooner as the system isnt like the old mechanical fan clutches, they are now computerized, i sold my 96 powerstroke because it wouldnt pull my new 34' fithwheel as it is 4000lbs heavier than my old one. i can pull this new 16,000lb one up steep long hills at 65mph. with the towmode engaged and the integrated brake controller i can go down long steep grades with little or no braking and the transmission does all the work. this truck so far is all i hoped it would be, i pull the 5th wheel 5 months a year and needed a new strong truck, so far so good
Old Oct 29, 2004 | 02:06 AM
tbirdrick's Avatar
tbirdrick
Wow
Sounds good Tom, If the trans guage never goes up, I would ask the dealer to check the accuracy of your temp guage. It sounds like the fans are doing their job. Ask what temperature the fans are set to come on at... that will give you an idea of what the temp guage is showing at that point..in real numbers.
Rick
Old Oct 29, 2004 | 02:11 AM
tom in las vegas
Thumbs up
sounds like good advice, ill ask them, i have only 1900 miles on it so far, ill have them go over it when i get the oil changed.
Old Oct 29, 2004 | 10:07 AM
Daryl Hunter's Avatar
Daryl Hunter
If you pull that much, you might consider getting a set of aftermarket gauges to monitor EGT, tranny, and engine coolent. I understand that the '05 already has a boost gauge built in.
On my '03 I can tow up a mountain and never see the tranny gauge move but my after market gauge will move from 165 to 195 or 200. The highest that I've ever seen it go was actually in stop and go traffic on the I-15 North and it hit 205 deg.
The factory tranny gauge will move from off the cold peg at around 80 deg and will be mid range by the time the tranny reaches 130 or so. So the factory gauges are really nothing more than window dressing idiot lights on my '03. If the tranny really gets hot, the gauge will probably sit there until it is almost in the danger zone and then jump from mid range to pegged hot in a very short time.
Old Oct 29, 2004 | 02:34 PM
tom in las vegas
thanks, ill look into the aftermarket guages, do you have any trouble with your engine temp or a late fanclutch when pulling up steep grades
Old Oct 29, 2004 | 03:31 PM
LOOnatic's Avatar
LOOnatic
I tow a little less weight with my 34' 5th (@14,ooo lbs.wet) wheel and yes,the condition you describe while pulling up a steep grade is what my truck does(engaging the fan and making that loud whirring sound) but not the overheating.
I suspect maybe a problem with the temp gauge.
You good always try to rig up a temporary 2ndary temp gauge and try to monitor the difference.
Good luck since i doubt Ford will be as concerned as you are.
Old Oct 30, 2004 | 08:20 AM
Ophus's Avatar
Ophus
This is a known problem on the 2005, there are some other threads on it around here somewhere. I don't think its overheating its just a gauge issue.
Old Oct 30, 2004 | 12:26 PM
tom in las vegas
i hope your right, i have already talked with a diesel specialist about putting together a gauge package for engine, trany and exhaust temp.
Old Nov 1, 2004 | 05:19 AM
Superduper's Avatar
Superduper
LOONATIC, Do you tow with an F250 dually? If you use a SRW, tell me what you think your wet pin weight is and how it tows. Thanx.
Old Nov 1, 2004 | 07:21 PM
tom in las vegas
i tow with a 2005 superduty f250 srw crew cab long bed, the king pin wt is about 2300lbs, it tows great, my truck is level after i load it, i used to tow with a 96 srw powerstroke and a 3000lb lighter 5th wheel, the 96 didnt like this new 16000lb 5th wheel so i got the 2005 powerstroke, what a difference!!! this new 5th wheel has an 8 foot ceiling all the way back so i have more side area for the wind to push around but the new truck pulls it fine and i dont notice any difference in handling. i talked to a friend who is the service manager at a ford dealer and he confirmed the 2005's have got a problem with the water temp gauge going to hot and emediately returning to normal when the fan clutch engages, as the water temp cannot be reduced this quickly its a program error and they said the computer shows that the motor is not overheating at all. he also said the transmission temp gauge is like a 3 position gauge: normal, yellow for getting hot and telling you to stop what your doing and red for you are frying things. he says they are working on a solution which should be reprograming the computer.
Old Nov 1, 2004 | 08:52 PM
IB Tim's Avatar
IB Tim
FTE Leadership Emeritus
TOM in VEGAS.....where I am currently at......WELCOME to the site, please read the Guidelines… Check out the list of forums and make sure you read the headings and Read First: notices in each forum.
Be sure to check out the 6.0 Bible…..great reading
http://dan.prxy.org/Truck/6L_bible_html/html/TOC.html
http://www.backglass.org/duncan/ps60_manual/
…. In the upper right hand corner of your screen check this out PARTS SHOP for all your “trucking” needs
Must read
http://www.clubfte.com/users/monsta/SuperDutyFAQ.html
Enjoy FTE
Old Nov 1, 2004 | 10:32 PM
milan's Avatar
milan
Tom,
my understanding was that Ford use mechanical gages. How computer can influent what these gauges show? It looks that Ford does not have solution and for now the easiest way is to say: yeah new re-flash will solve your problem.
Anybody else seen the same problem? Keep us informed…
Old Nov 19, 2004 | 06:17 PM
J.Lauer's Avatar
J.Lauer
Same problem here. I have a 32ft 5th wheel weighing in around 13,000 lbs. First time towing trailer up short, steep, grade the fan kicked on and the temp gauge ran to the top and immediately returned to normal?
