7.3 removal
I have a bad oil leak thinking its coming from the timing cover at the top next to the HPOP . Had a mechanic have ago at it but he failed ,so thinking taken it out would be the best way to fix it ...
while its out mite do some mods , get the turbo seviced aswell ,new DP ,new up pipes as mine are leaking , and a few other deletes while out..
do u no wer i can get a gasket kit from other then Ford ???
can you think of some modes i should do while its out ??
thanks mat..
Is there oil in the valley at the front under the HPOP?
If so I suspect you my be leaking from what Ford call an "unserviceable" plug
in the bottom of the HPOP.
Apparently it is a common problem, I just had to fix mine.
The plug is serviceable if you do it right.
I can give you links to some PDFs and youtube videos about
the job if you think that might be the source of the leak.
As for parts, I get a lot of stuff from here:-
RockAuto
they have a huge range and good prices.
yes oil from the valley under the hpop and from around the sump ... the mechanic thought it was coming from the timimg cover from under the hpop ...
the sump leak is from wen he removed it and didn't seal it properly ...
would be keen to see a video or some links ...
thanks Mat
thanks Mat
This lot should supply plenty of reading.
Powerstroke Mods and Maintenance
https://www.ford-trucks.com/forums/5...look-here.html
https://www.ford-trucks.com/forums/6...fferently.html
https://www.ford-trucks.com/forums/6...your-hpop.html
https://www.ford-trucks.com/forums/5...tallation.html
99-03 Turbo Removal & Wicked Wheel Installation - Ford-Trucks.com
http://www.forddoctorsdts.com/articl...icle-05-10.php
Instruction Sheets and Information
http://www.dieselorings.com/docs/service_plug.pdf
http://www.dieselorings.com/docs/dipstikflange.pdf
CNC FABRICATION 7.3L E99-03 COMPLETE REPLACEMENT HPOP AND HPX LINE KIT - 99-03-ENGINE - POWERSTROKE 99-03 - Products
https://www.strictlydiesel.com/p-275...-bolt-kit.aspx
High Flow Fuel CVD Fitting Set for Ford 7.3L 99-03
7.3L Diesel Fuel Rail Crossover? (FRx) 99-03 Powerstroke
More Information for ROTOMASTER A1383801N
More Information for ROTOMASTER A1382205N
More Information for DORMAN 679005
Welcome to guzzle's Ford PSD Web Pages
Welcome to Pocket's International UP-Pipe Replacement Web Page
Welcome to guzzle's Plenum Reinforcement Insert Installation
Welcome to guzzle's In-tank Hutch Mod Web Page
Blog | Ford Diesel Performance Parts Blog
http://www.dieselsite.com/
http://dieselsite.com/pdffiles/adren...structions.pdf
http://www.dieselsite.com/pdffiles/TM73Install.pdf
http://www.dieselsite.com/pdffiles/h...nginetemps.pdf
Installation
http://riffraffdiesel.com/content/RE...structions.pdf
http://www.riffraffdiesel.com/conten...structions.pdf
http://www.riffraffdiesel.com/conten...eplacement.pdf
Ford Super Duty Documents - Superdutypsd.com
Ford Super Duty Maintenance Information - Superdutypsd.com
Ford Super Duty Write-Ups - Superdutypsd.com
Have fun!
I will bet yoour problem is up top. First thing to do is clean the heck out of the valley. Most common leak is the exhaust back pressure valve in the turbo pedestal
Hear ya go
https://www.ford-trucks.com/forums/1...tor-build.html
lol.just read your last post properly. wtf did your mechanic do with the sump ???
