4-6" lift 14 F350 decision time
Fordman thanks! Yes Projectnitemares recommendation was spot-on. It was a little more complicated than what he made it sound like OR I just took it to a whole nother level, which is probably more like it lol. I cut the bracket connecting the two down down pipes and also moved the 1st hanger up 1" higher on the frame I also made a new hanger and welded it to the turndown coming out of my resonator where I deleted the muffler. Looks super clean and the exhaust is fully supported so it doesn't rest on the crossmember. I was able to use one of the deleted hangers for this and drilled into the crossmember where the bed meets the cab. In order to get everything free enough to move I had to loosen both down pipes from the manifolds. It was a lot of work but I love the way it turned out. People will probably think I'm crazy but I swear the drone in the cab was lessened a bunch when I made that final hanger and connected it to the turndown coming out of the resonator. After all was said and done the catalytic converter clears the front driveshaft by at least 1.5"
glovemeister
13
02-01-2011 06:01 PM
fordman1090
04-24-2010 09:00 PM
