keyless entry 1996 PSD
For Model Years 1995-97: Cycle the ignition from OFF to RUN/ACC five (5) times within 10 seconds, ending in RUN/ACC, or cycle the ignition from OFF to START three (3) times within 10 seconds, ending in RUN. The power door locks should cycle LOCK to UNLOCK to confirm entrance into Program Mode.
For Model Year 1998 (Windstar/Escort/Tracer/Navigator): Cycle the ignition from OFF to RUN/ACC eight (8) times within 10 seconds, ending in RUN/ACC, or cycle the ignition from OFF to START four (4) times within 10 seconds, ending in RUN. The power door locks should cycle LOCK to UNLOCK to confirm entrance into Program Mode.
Press any button on a remote entry transmitter. The power door locks should cycle LOCK then UNLOCK to acknowledge transmitter code.
Repeat Step 2 for any additional remote entry transmitters that need to be programmed to the vehicle.
Turn the ignition switch to OFF to exit Program Mode. To confirm Program Mode has been exited, the power door locks will cycle LOCK then UNLOCK one last time.
Found it on FTE in the TSB lists.
https://www.ford-trucks.com/tsb/full...hp?tsb=97-11-5
NOTE: The remote entry receiver module erases all previous transmitters from memory when the transmitters are programmed or reprogrammed. The remote entry receiver module can store up to four transmitters in memory.
To program (or reprogram) transmitter(s) into the remote entry receiver module, perform the following steps:
- Turn key to the ON or ON/ACCESSORY position and momentarily short the two terminals of the program connector (C4) (a two-pin connector taped to the wire assembly connected to the remote entry receiver module, approximately 6 inches from the remote entry receiver module). All doors should lock then unlock. Remove shorting pin.
- Press any button on transmitter. All doors should lock then unlock to verify that the transmitter has been programmed. If door locks do not respond, press button again (up to three times maximum with the same transmitter).
- Repeat Step 2 to program additional transmitters into the remote entry receiver module (up to four transmitters maximum).
- Key off. All doors should lock then unlock.
- Check operation.
- Check operation.
