Distributor O ring
Old May 13, 2016 | 12:14 PM
JayFinAZ's Avatar
JayFinAZ
Distributor O ring
I've got quite a bit of oil leaking around the distributor and I need to replace the O ring (if there is even one left). But I didn't have much luck disconnecting the wiring harness from it today. I quit before I broke the connector. What's the right way to get these apart? I was trying to pry the clips with a screwdriver and pull it apart, but I'd need about 4 hands to do it that way I think.
Does anyone know what size O ring I need? It's a 1983 300 I6, DSII.
Old May 13, 2016 | 10:24 PM
kr98664's Avatar
kr98664
I don't know the size, but am pretty sure NAPA will have it. They had the O-ring for my '84 351W. Not sure if the 300 takes the same size, but even if different, I bet they'd have it.
Tried to find it on their website but couldn't get it to display your engine for some odd reason.
Old May 13, 2016 | 10:42 PM
JayFinAZ's Avatar
JayFinAZ
Thanks! I found some tools on ebay for the electrical connectors, I hope they work
Old May 14, 2016 | 06:58 AM
Franklin2's Avatar
Franklin2
The plastic is so old now, the latches on the connectors will break, no way to get around it sometimes. They usually hold together fine without them though when you put it back together.
neelyjosh
Jun 18, 2017 09:08 PM
hermancm
Aug 27, 2013 07:44 PM
hermancm
May 16, 2012 10:29 AM
JhnBrackett
Feb 18, 2004 04:29 PM
CantDrive55
May 6, 2000 04:46 PM
