OBD link - one more try.
Old May 12, 2016 | 09:56 PM
finallyo3gt's Avatar
finallyo3gt
I've never been able to get Torque to communicate with the PCM. I also have a Autel Maxidiag 801 pro, that seems to connect to some degree but won't actually do anything productive. I've also got an odd starting issue where it lopes VERY badly without a slight throttle input. I do mean slight, sometimes not even enough to raise the RPM.
So today I wanted to chase my suspicions of my TS-6 interfering. I pulled it out and viola, starts perfect. But still no data link from torque or my scanner. My scanner has a "component check" and that makes some relays click somewhere under the hood, and cycles the WTS light. So there is some sort of link.....
I know plenty of guys run Torque, but right now, I'm scared to even drop the $$$ on something like edge or AE b/c I'm afraid I have some sort of communication failure with the PCM. ANY ideas?
Old May 12, 2016 | 10:11 PM
fordpride's Avatar
fordpride
Your chip might be tuned for a 5speed. If so its no recognizing the TRS causing it to lope.
Put the chip back and start in N see if it stops loping
Old May 12, 2016 | 10:17 PM
finallyo3gt
I'll try that, but... it definitely has some influence over shift points and TC lock up.
Old May 13, 2016 | 10:50 PM
finallyo3gt
Tried a neutral start. No change. The hunt continues I suppose.
Old May 14, 2016 | 06:55 AM
fordpride's Avatar
fordpride
If it only does it with the chip then something is wrong with it or the tuning
Old May 14, 2016 | 08:50 AM
finallyo3gt
Agreed. The chip does affect the mapping of the throttle pedal it seems.
I REAALLYYY wish I could figure out whsts up with my OBD comms.
Old May 14, 2016 | 09:35 AM
fordman67's Avatar
fordman67
Have you gotten the device to "pair" with your phone or tablet?
I have torque and I will say it's a finikey deal.
Old May 14, 2016 | 09:39 AM
finallyo3gt
Yes. In the torque status all green except comms with pcm. Multiple attempts
Old May 14, 2016 | 09:51 AM
fordpride's Avatar
fordpride
Have you checked the fuse ?
The cig lighter fuse controls the obdII port
Old May 14, 2016 | 10:06 AM
finallyo3gt
I have checked for voltage per wiring diagrams, and done ring outs from the PCM plug to the OBDII. Check fuses (power port and cig both in use, so I'd know if they popped), and checked voltage again. The scan tool will power up as soon as I plug it in. Also, when I run a "component check" on my scanner, I hear some relays click, and my WTS light cycles, so there is some communication to something..haha.
Old May 14, 2016 | 10:07 AM
finallyo3gt
I wondered about communication protocols. Is it possible my truck is NOT OBD enabled?? Would that cause the issues I'm having?
rideracelivemx7
Oct 6, 2009 07:10 AM
Robbgt
20
Mar 12, 2008 09:16 PM
trike1946
16
Jan 8, 2007 05:23 AM
generalee31184
Feb 25, 2006 07:08 PM
Desieldummy
Jun 19, 2004 05:57 AM
