Yeah my concern was my 87y/o grandmother being able to get in and out. She uses a cane and is able to get in now with a step stool and the factory running board. I just want to do away with that plastic tan running board. Thanks
It's much easier with the amps, there is no question in my mind...
Mother inlaw is 87 my mom is 91 and uses a walker.
I used a step stool than on to the non slip of the amps, much easier!
A friend of mine is doing the wiring. I wanted them tied to my alarm along with the door handles, adding a bunch of led strips for puddle lights and a bypass switch. He's also hooking up my two 50" led bars and my 40" back up bar. I anticipate a couple hundred bucks. He is not using the obd2.
I don't know about the AMPs because I have the Bestop version, but wiring them into the door switch is pretty simple, the wires are right under the plastic door sill that just snaps in place.
