Rattle noise in dash
Got a rattle noise in dash that comes and goes it sounds like it is behind radio. Kind of a loud solid sounding noise.
It will do it sitting at at idle occasionally, it will do it when hitting bumps in road occassionaly
Can not find any consistency sometimes its just a little and sometimes real bad, and sometimes nothing at all.
I pulled radio out but cant feel anything loose back there.
Thanks.
Thanks.
on
I would pull the radio and then drive the truck for a little bit until I hear the noise again. Keep removing dash pieces until you find it.
Rattles and wind noise drives me crazy, I have to stop it as soon as it starts. It really sucks that I have a passenger that like to have his window cracked all the time.
I had the same thing, I thought it was my radio but ended up being the screw in the top middle of the dash just needed to be tightened up. There is a plastic cover on that screw you will see it if you look near where the dash meets the windshield. I think there are 2 more at each end of the dash as well.
I found it, so now momma will be happy, well hopefully.
Checked the top dash screw and gave it a couple turns, to no avail. Although that was the area it was coming from.
felt all around under dash, behind radio and couldn't seem to locate it.
Couldn't hear it outside the truck either.
But started feeling around under the hood anyway while wife sat in truck listening.
Moved a small hose, and she honked horn at me, and said it stopped.
There is a 3/4" hose on the driver side that goes into a metal crossover pipe at the back of the engine compartment fire wall and goes over into something on passenger side. Anyway it is held to firewall by two studs and one of the 10mm nuts was backed half way off on the driver side, rather I should say, some ash hole didn't get it all the way back on, and it weren't me.
I have checked under the hood and don’t see that same hose on my V10. I also have removed my glovebox and had my wife drive GM the other night and it sounded more like the noise was coming from the passenger side fender area. I removed the fender liner the next day and found the antenna wire in there and possibly could be hitting the sheet metal of the inner fender. I put a rubber hose around it and zip tied it in place, but that wasn’t it either.
here is a video I took the other night with the glove box out. Has anyone heard this same noise and what was the culprit? I can’t for the life of me find it.
silver2004xlt
10-04-2004 07:41 AM
