Failed pcv attempt.
Old May 11, 2016 | 12:06 AM
91Fbody's Avatar
91Fbody
Failed pcv attempt.
Thought this would pull air from the oil fill tube, through the engine, and out of the valve cover. Doesn't seem to be creating any vacuum at the oil fill neck. I blocked off the draft tube temporarily since I haven't removed it yet, but didn't make a difference in vacuum(just using my hand). Haven't done any compression checks but I'm sure the engine isn't in great health, but it isn't especially smoky under the hood with the draft tube setup either.
I'm using a pcv valve from a dodge stealth (3.0/turbo). Figured it would be big enough. The valve covers might not be creating a good seal. I tightened them a bit with no difference.
Any idea why? Should I plumb vacuum to the valley pan instead?
Old May 11, 2016 | 01:09 AM
Jules The Great's Avatar
Jules The Great
I would think your biggest "air leak" is going to be the oil filler tube I can see on the other side of your engine there. Nice setup though, I want to do something similar. Although I might suck from the oil filler tube instead of adding holes.
Old May 11, 2016 | 09:32 AM
tinman52's Avatar
tinman52
Welder User
It would work better to put it where the road draft tube attaches. In the valve cover, without a baffle, it will just suck oil.
Old May 11, 2016 | 05:16 PM
91Fbody's Avatar
91Fbody
That's where I want the source of crank vapors to be. I'm just not seeing it there.
I figured I'd have a higher risk of sucking oil plumbing it to the draft tube location. I had planned on making a baffle if the valve cover worked.
Old May 11, 2016 | 06:05 PM
Jules The Great
I see what you are saying, not sure where else air would be leaking in? Do you have a vacuum gauge? Check the hose and make another plug for the oil filter to treat pressure there?
Old May 11, 2016 | 06:06 PM
bobbytnm's Avatar
bobbytnm
Roast em' if you got 'em
I'm interested in this solution also. I have a buddy with a "Y" block in his 55 T-bird that wants to get rid of the road draft tube.
My idea was to pull the road draft tube and replace it with a grommet and PCV valve plumbed to the carb. Now I'm not so sure if that will work. I hadn't thought about the vented oil fill cap.
Bobby
Old May 11, 2016 | 06:18 PM
ALBUQ F-1's Avatar
ALBUQ F-1
Bobby
That's exactly how PCV is done on flatheads. Sucking in air thru the filler cap is fine, it helps sweep out condensible vapors. On 8BA flatheads the draft tube is connected right to the crankcase, while the filler is connected to the lifter valley. Air comes in the front of the valley, sweeps along to the rear of the valley and down into the crankcase, forward to the front of the crankcase and up and out the draft tube. I'd assume they did a similar pattern on the Y-blocks.
On the Y-block, you may need to let air in BOTH valve covers, and take it out the draft tube opening. I doubt you could feel the vacuum by putting your hand over the filler cap, the PCV valve meters a controlled amount of air.
Old May 12, 2016 | 12:59 AM
jimcar-9's Avatar
jimcar-9
The older Y blocks has the oil filler cap as the inlet port and the road draft tube as the outlet (sucking) port.
But there are actually later models y block with a stock outletport in the rear of the valley panreally close to the vacume port on the carb plate. Barley noticeable.
Inlet is still the oil filler cap.
However I find the road draft tube outlet position (theoretically) more efficient as the inlet is in the front top and the air is sucked thru the entire motor (thru lifter gallery and down in the rear and than thru the entire crank case and out in the front.
Thats not the case with the valley cover position. Then you only vent the top half of the engine...
Just my ten cent
Old May 12, 2016 | 01:55 PM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
PCV introduced in 1961, was mandatory in all I-6 & V8 sold new in CA vehicles, other states may have mandated it as well.
292 Y block - Lower pic / 6A665 adapter took the place of the road draft tube, 6A666 is the smog valve.
Old May 25, 2016 | 09:44 PM
91Fbody's Avatar
91Fbody
Thanks! I should be able to get it working now.
TexasTornado66
Feb 25, 2022 02:29 PM
gusso
13
Oct 31, 2008 03:12 PM
txwing
15
Oct 29, 2003 06:04 PM
MuchToMyDelight
Sep 11, 2003 12:54 AM
atticmole
Sep 1, 2003 07:52 PM
