Sponsored by: Auxito
Misfire problem
Old May 10, 2016 | 10:27 PM
NUKEHEAD1001's Avatar
NUKEHEAD1001
Misfire problem
i have a 99 f150 4.6 and i have a misfire problem i believe. when i accelerate in all situations the truck has a loss of power and will shake. no engine code is being thrown. the first time i had this it was the spark plugs so i replace all 8 and my truck was fine. that was about 10k miles ago. a few months later the same thing was happening and a code was thrown and it was a misfire and i replaced the coil pack that caused it. now its happening again. i wonder if its the other coil pack because i only replace 1. (i have 2 coil packs with 4 spark plugs to each). any ideas on what could be causing this misfire.
Old May 11, 2016 | 12:25 PM
steve(ill)'s Avatar
steve(ill)
you need the code for the specific cylinder or coil...... something else to remember is each time you work on a plug or coil, you remove and reinstall a few plug wires and power wires... may have a bad connection / cracked wire / corroded terminal ?
marcrex
2004 - 2008 F150
Mar 27, 2019 11:08 PM
dsundby10
Dec 23, 2013 05:30 PM
2jhanna
1997 - 2003 F150
Jan 21, 2009 03:24 PM
haldavis
3.8 & 4.2L V6
17
Dec 11, 2008 06:33 PM
swhite005
1997 - 2003 F150
Dec 19, 2005 07:42 AM
