Glowplug removal problems. NEED HELP!
Old May 11, 2016 | 09:25 PM
Otto396's Avatar
Otto396
Originally Posted by willpjones
I took a good look at each of the plugs today and the threads are definitely the same. It must just be the way I took the picture. All the plugs worked well when I hooked them up to a battery today.
I'll bet they got d@mn hot!
Old May 12, 2016 | 07:44 AM
Walleye Hunter's Avatar
Walleye Hunter
Hooking them up to a battery sounds like fun, did you spray them with a variety of flammables for thrills and excitement?
Old May 12, 2016 | 07:54 AM
Otto396's Avatar
Otto396
Sounds like something I'd do...
Old Jun 6, 2016 | 08:50 AM
willpjones's Avatar
willpjones
Buying used injectors
I just bought a set of used injectors. The only have 80,000km on them and oiled and kept in bags. The thing is they haven't been run in a couple years. Am I in trouble with these injectors? Anything I should do before install?
Old Jun 6, 2016 | 09:58 AM
Otto396's Avatar
Otto396
If it were me I would inspect the nozzles for coking and make sure there isn't any scoring on the bore above the nozzle otherwise they won't be able to seal. Replace all of the seals and make sure there aren't any copper washers left in the heads. Other than that... You could do a buzz test on them to make sure the solenoids works. You cant fully test them without a flow bench or installing them to see how they run.
Old Jun 6, 2016 | 10:03 AM
willpjones's Avatar
willpjones
Sounds good. The injectors look in good condition and have no obvious sign of wear. I will buzz rest them once I install. Do you think the plunger could seize from sitting so long?
Old Jun 6, 2016 | 10:24 AM
HKusp's Avatar
HKusp
Anything is possible, but I am sure there was residual oil in them when they were packed by the original owner. I would install them and run the buzz test like Otto said, then go from there.
Old Jun 6, 2016 | 10:28 AM
willpjones's Avatar
willpjones
Thanks for the input. I'm hoping they will be good
Old Jun 6, 2016 | 10:48 AM
HKusp's Avatar
HKusp
If you trust who you are getting them from, you should be good.
Old Jun 22, 2016 | 04:48 AM
willpjones's Avatar
willpjones
Park brake pedal cruise control problem
Thanksgiving jbvsg
Old Jun 26, 2016 | 12:36 AM
snknby123's Avatar
snknby123
May be worth sending them in and have them flow tested on the bench. Couple hundred bucks could save you a lot of headaches down the road.
Old Jul 22, 2016 | 09:12 PM
willpjones's Avatar
willpjones
I'm not to sure what you mean? Spark plugs and ignition coils in the transmission?
Catlan Zuliani
25
Nov 18, 2018 11:43 PM
Catlan Zuliani
Aug 28, 2018 12:40 AM
1999SuperDutyStroke
26
Apr 28, 2010 07:04 PM
Rik62
Aug 12, 2006 02:45 PM
bigwill44
Nov 2, 2004 06:28 PM
