Rear dvd
Old May 10, 2016 | 06:33 PM
fordboy2's Avatar
fordboy2
Rear dvd
Ok did some searching and did not have luck on finding a solid answer. Can anyone tell me what's needed to be done to retain the rear did and add an aftermarket headunit/dvd player. Thanks in advance.
Old May 10, 2016 | 06:34 PM
rockhounds4x4's Avatar
rockhounds4x4
call crutchfield they have all kinds of harness adapters that would let you keep factory radio components.
Old May 10, 2016 | 07:00 PM
fordboy2's Avatar
fordboy2
I did they told me there is nothing available and would have to loose the rear did to go
Aftermarket.
Old May 10, 2016 | 11:04 PM
hwybee22's Avatar
hwybee22
Yes, you can still keep the rear DVD player. I could run everything from my Alpine. The audio shop had to plug into the front of the DVD player using the plugs. I wanted a cleaner look, but I was told that was my only option.
Old May 11, 2016 | 06:38 AM
Atc210's Avatar
Atc210
If you are good at soldering, just cut the RCA off the connecter and solder it to the connections on the back of the DVD unit.
Old May 11, 2016 | 12:49 PM
copsey's Avatar
copsey
I was able to keep the rear DVD with my Kenwood install, however the lower plate with the headphone jacks is no longer functional. Keeping my eyes open for a new style with the infrared headphones to swap out.
Old May 11, 2016 | 01:04 PM
Country_Mouse's Avatar
Country_Mouse
I just posted in the other thread on front page about this. I bought a set of 4 infrared headphones of Amazon. My rear display is supposed to be capable of infrared but looks like my Pioneer head unit may not be hooked up in the back properly to enable dual zone. Haven't tried pulling g that out to check yet because I really don't know how to....Eventually will take to Best Buy or somewhere to let someone else troubleshoot.
Old May 11, 2016 | 01:52 PM
gots_a_sol's Avatar
gots_a_sol
Thread in the tech folder on rear dvd with aftermarket radio
https://www.ford-trucks.com/forums/1...l#post11706047
Old May 12, 2016 | 10:29 AM
03X's Avatar
03X
Aftermarket.
take 12 minutes and watch this:
Old May 12, 2016 | 11:25 AM
copsey's Avatar
copsey
If your display has the two black sections and the bottom left and bottom right you should be able to get the wireless headphones working. As far as I can remember that is a completely seperate circuit and does not interact with the head unit at all.
Old May 12, 2016 | 11:55 AM
Country_Mouse
My rear display? It is aftermarket too.
Old May 12, 2016 | 03:08 PM
copsey's Avatar
copsey
Ahh, that being the case you should be able to tie into the display and use it as an input into the aftermarket radio. I know it's possible on the radio I installed on our EX.
thor363
Jul 13, 2019 06:34 PM
JROCK_OH_TX
May 28, 2016 09:46 PM
gotgig
Jul 13, 2011 03:09 PM
wrangler2520
Apr 4, 2009 11:07 PM
johnfum
Mar 28, 2005 02:57 PM
