Well found this hole today and figured it wasn't supposed to be there. Can someone enlighten me on the name of this part? By the looks I assume I can just replace that cover piece?
I might be mistaken about a manual not having one. Cause it definitely looks like a trans/flywheel inspection plate. If I were home I could look under mine to verify (I also have a manual 4 speed.) Do you know which 4 speed it is?
Yep, now that I know what the part is, the hole makes sense lol. Was partly worried since I'm fixing a few leaks and there was some dripping from the hole
Thanks numberdummy that'd be the part! Is the rear main seal easy to change?
Depends if our trucks have one piece or two piece seals. I believe they are one piece rear mains which means separating the trans from the engine to remove and replace.
