!!Cab Electrical Problem!!
Old May 10, 2016 | 10:20 AM
4speedspring's Avatar
4speedspring
I have a 1984 F-150 Base model standard cab. I started it up this morning to let it warm up and not thinking anything of it i turn on the heat and go back in the house. I get back in it and drive down the road. I noticed that the radio so i clicked it on and nothing happened. I turned on my fan, nothing. Turn signals, cab light, headlamps, NOTHING. the only thing that works is the hazard lights. It runs and drives fine too. I looked in the Chilton manual and switched one unmarked fuse to the horn because the horn didn't work. I have no idea whats going on!
Old May 10, 2016 | 10:29 AM
bcamill's Avatar
bcamill
Try to jiggle the ignition switch some. These trucks are notorious for the arm that leads to it getting sticky and this will cause directional and such to not operate. If that is it, you will need to lube it some. Easiest is to drop the column to get at it.
Old May 10, 2016 | 10:43 AM
4speedspring
Thank just got it working I'll try to look for new components for it like a spring or somthing
Old May 10, 2016 | 01:29 PM
1986F150six's Avatar
1986F150six
Welcome to the forum, 4speedspring! You can find a wealth of information in the "stickies" section... https://www.ford-trucks.com/forums/1...mechanism.html
Melonmuziq
May 25, 2018 02:33 PM
Old Brown Truck
Nov 13, 2014 01:11 AM
RÖENTGEEP
Jul 24, 2012 09:42 AM
Anafiel
23
Nov 27, 2010 03:32 AM
Back265
Jan 29, 2010 02:18 AM
