Hub Bore Question
Old May 9, 2016 | 10:51 AM
POL_Sarge's Avatar
POL_Sarge
Hub Bore Question
Howdy folks,
1978 F100 LWB, straight 6, just a quick question regarding the subject-
I recently bought some Dodge 20" rims for this truck, but have a problem with the hub bore size of the rim not matching the hub bore on the rotor (rim bore is about 3/8" too small).
I have used the search feature, and turned up few results.
Seems to me the easiest option is to have the hub bore milled out to fit the rotor? Has anyone had to do this? Looking for some useful insight folks.
thanks!
Old May 9, 2016 | 11:25 AM
HIO Silver's Avatar
HIO Silver
Search this and compare between vehicles.... Wheel Bolt Pattern Cross Reference Database and Conversion Guide
Then have the rotor machined to fit the wheel... not vice-versa.
Old May 10, 2016 | 09:25 AM
POL_Sarge's Avatar
POL_Sarge
Thanks HIO. I've got that part figured out. they are 5 x 5.5. problem now is hub bore. are brake shops willing to machine down the hubs? i would think not because of liability?
Old May 10, 2016 | 11:13 AM
HIO Silver's Avatar
HIO Silver
That database lists the hub bore diameter... one of the few that do and that's why I posted the link to answer your question.
Brake shops probably won't be able to do what you need done.. they'll resurface a rotor but are typically not equipped to do real machining that an engine or machinist shop would do.
jlatr
Mar 3, 2016 11:36 AM
03' Excursion
Apr 15, 2011 10:18 PM
quisp
Aug 7, 2010 05:15 PM
scootin
1978 - 1996 Big Bronco
Feb 10, 2007 01:54 PM
