Sponsored by: Real Truck
2002 Ford F-250 door lock problems
Old May 8, 2016 | 05:19 PM
JakeTheFordKid's Avatar
JakeTheFordKid
I was wondering if anyone has come across this problem before.
Truck:
2002 F250 lariat 4 door cab 4x4
The Probelm:
The door locks will stop working after sitting for 15 mins or so. I can get them to work again by disconnecting the battery then and connecting it again. Then like magic all 4 locks work again, but if I let it run they will work until it's off and sitting for 15 mins or so they will stop working. I've checked the fuses and disassembly the fuse box to look for any damage but it looked fine. Any advice would be greatly appreciated.
Old May 13, 2016 | 05:17 AM
kengarchow's Avatar
kengarchow
i would think a ford tech could figure this out
bummer to have to take to a dealer to fix though
i have had some luck with the on line pay services where you can get help from techs that side line
Old May 14, 2016 | 01:09 PM
ligito's Avatar
ligito
Check all of your ground connections, too.
Old May 14, 2016 | 01:15 PM
dkf's Avatar
dkf
I'd check all the wires going from the cab to the door for cracking, corrosion or breaks just to rule it out. I just ran into an intermittent issue similar with an Explorer and it turned out to be a broken wire making intermittent connection.
Old May 17, 2016 | 10:27 AM
f250mtnbikr's Avatar
f250mtnbikr
JakeThe FordKid,
The schematics show the "Vehicle Security Module" (VSM-has to do with the remote locking, etc.) as the place where the switch signals go to activate/deactivate the locks.
It's a black box on the schemats, so no help other than replacement if the problem is there.
As said by others, check all the connections you can ascertain are involved.
I am not sure what issues, if any, you would create by reseating the connectors on the VSM (possible alarm signal, etc?). I would hope none, but I would research some before doing it.
Good luck, Tom
Mr_CarMan007
Mar 4, 2016 11:52 AM
Wingnut77
Jul 10, 2014 08:30 AM
Shovel7d1
Apr 22, 2014 11:25 AM
bob_m10
Electrical Systems/Wiring
Sep 14, 2008 01:15 PM
jle70
May 16, 2007 08:36 PM
