Dome Light Issue
98 Ranger XLT
V6
Manual windows
If the light goes out, but the relay does'nt click when removed, try replacing it.
The relay box should be under the hood. If you dont have the owners manual flip the lid over and there should be a diagram showing which relay it is.
Strange that there is no mention of the interior lamp relay location?????
Those relays include: the interior-lamp relay, and the battery-saver relay.
If you can find it I'll have a super mod put the link in the Tech Info thread.
If the doors are closed when you hear the relay clicking my WAG (wild *** guess) is that the GEM could be hung up & keeping the relay trip wire grounded. Try removing the battery ground wire for a couple of minutes and see if it does anything.
Could also be a bare wire grounding out somewhere.
Wish i had the factory diagrams for a 98. It's hard to figure this sort of thing out with the disjointed online diagrams.
On my 99, the position of the power window relay, located on the metal tongue below the glove box door, is labeled as the interior dome light relay on some models. It's unlabeled location can be seen in the above pictorial, laying horizontal to the left of the red pointer that's indicating the aux relay box location EDIT: Here is another view & labeling of the dome light/accessory delay relay & its location below the glove box door hinge http://ww2.justanswer.com/uploads/s4...y_location.jpg. So the relay you hear clicking should be in one of these two places.
pawpaw: It wasn't me who posted the pics of the relay box, but I was able to find the thread that you are probably thinking about:
https://www.ford-trucks.com/forums/8...t-working.html
Also, for further ID purposes, the interior lamp relay "connector" has 5 wires, as follows:
pin 30 = BK/LB
pin 85 = LG/O
pin 86 = LG/O
pin 87 = LG/O
pin 87a = BK/PK
I see the photos are for a 2001 & I thought it was for an earlier model Ranger. I remember at the time going out to my 99 & looking for it to the right of the steering column because I was having power window & lock problems but couldn't find that danged aux relay box. So not certain its in that spot for a 98 like the OP has, but at least we know what that puppy looks like & what's in it, when we do locate it on our particular model Ranger. If he can have a helper remove & plug in the fuse that makes it click while he zeros in on the noise, bet he'll find that puppy & maybe enlighten all of us on his findings.
It's under there on my '98, so I assumed it would be there in all Rangers of the same vintage....
...OK, I just looked over the schematic again and I do see some asterisks which indicate that in some "base models" the two relays (interior lamp and battery saver) might be found behind the glove box, instead of in that relay box. But I'm not sure what it means, because you noted that your '99 has PW/PL in any case, which doesn't sound like a "base model" to me (but maybe it is to Ford?)
So I guess what I am saying is that, once again, Ford has me confused.
So your '99 doesn't have that relay box?
Right now I have the center bezel that holds the radio & AC louvers out, so there is a Big hole in the dash & I can clearly see what's back there & I'm still not locating where that relay box is.
There is a sorta flat rectangular module cram/mounted on the upper left inside the opening, onto what looks like the side of the instrument panel mounting structure. It's almost impossible to see clearly what it is, but I suspect it's probably the GEM. I can't find anything else back there that looks remotely like the Aux Relay Box.
SO, right now I'm wondering if its maybe been moved behind the drivers side kick panel on my year/model????
For instance, I recently found my Accessory Delay Relay/Power Window Relay, dangling inverted by its wiring pigtail, over behind the passenger kick panel, instead of under the glove box door tang, where the FSM illustration here shows its supposed to be. Note that the illustration indicates there is some difference in what the relay in that position does, depending on if the vehicle is as noted (Without power equipment, or 4X4) http://ww2.justanswer.com/uploads/s4...y_location.jpg.
After finally finding it & reworking/cleaning my relay & its contacts up, I installed it on the metal tang under the glove box door, where the FSM illustration shows it's supposed to go. It clipped onto that tang just like it was supposed to.
I've had the truck since new & no one has done any in cabin repairs or maintenance, so I believe it came from the factory installed out of place.
Another member had found his Accessory Delay Relay hanging inverted by its wiring pigtail behind the passenger side kick panel also & thank goodness he had posted where he found it, sure saved me my best cuss words & more skinned knuckles trying to find mine where it was supposed to be, but wasn't!!!
SO, who knows where my 99, or the OP's danged 98 Aux Relay box is, but now that we once again know what it looks like & what's in it, maybe I/we can use the OP's fuse pulling scenario to make a relay in the aux relay box click & discover its location by sound!!!???
But now I'm so old that I've got to have a helper with young ears to listen for the relay click, while I jiggle a fuse!!! lol
SO, if the OP can't find his 98 Aux Relay Box where the 01 Ranger aux relay box photos show it to be, or where you found your 98's to be, he can use his ears to locate that puppy & clue us in on where to look on a 98 equipped like his & maybe I'll find my 99 relay box there too!!!???
Stay tuned, the Aux Relay Box/Dome light relay location saga continues!!!! lol
