3.31 rear axle
Old May 8, 2016 | 12:12 PM
northernsnooker's Avatar
northernsnooker
3.31 rear axle
Anybody have 3.31 rear axle ratio and wish they had 3.55?
I'm looking at a 2016 250 lariat 4wd supercrew. Truck has everything I want but has 3.31.
Will I be disappointed in throttle response or acceleration?
This is my first diesel. My current 5.0 f150 has 3.55 and I wish it had 3.73.
Thanks
Old May 8, 2016 | 12:26 PM
k7lvo's Avatar
k7lvo
I've had a 7,000# trailer behind mine for the past 600+ miles. It pulled Cabbage Hill on I-84 in eastern Oregon eastbound at 55 in 5th. It did drop to 4th one time when I had to accelerate to pass a truck.
I've got 20,000 miles total on it, and I've never wined for lower gearing
Old May 8, 2016 | 12:55 PM
Ricohman's Avatar
Ricohman
I always go for the deeper gear set.
It won't cost you anything in mpg. And it will accelerate and tow like a champ.
Old May 8, 2016 | 01:05 PM
Pocket's Avatar
Pocket
I have the 3.31's and my truck tows quite a bit. Never had an issue, never felt like I needed the 3.55's.
Old May 8, 2016 | 01:45 PM
69cj's Avatar
69cj
Sorry started to say mine had 3.31 but on further check it's 3.55. I personally don't think you'd really notice the difference they are so close.
Old May 8, 2016 | 02:31 PM
Thenewboss's Avatar
Thenewboss
I bought my 6.2 with 3.73s and wished I held out for 4.xx. That said, the 3.73s on my current truck can really haul the mail behind the 6.7. I'd say if it's enough of a concern to ask, hold out for what you want. And the others are right too, not much difference between 3.31 and 3.55.
PD...hauling a 9000lb camper up any grade I have encountered it has never downshifted unless I commanded it to.
Old May 8, 2016 | 03:25 PM
ruschejj's Avatar
ruschejj
The way the trucks are built it goes approx:
3.55 with 20" wheels = 3.31 with 18" wheels.
It's not possible to buy a stock truck from ford configured 3.31 with 20" wheels. I'm not sure if you can get 18" and 3.55, probably.
Old May 8, 2016 | 03:57 PM
Dascro58's Avatar
Dascro58
Just FYI, my truck (in my sig) has 3.55 with 18" tires. It tows like a monster!
Old May 8, 2016 | 04:31 PM
northernsnooker
I am considering 2 trucks.
One has 18" wheels with 3.31 gears. One has 18" wheels with 3.55 gears.
Sounds like either is fine. I'll go with the best deal.
Thanks
Old May 8, 2016 | 04:40 PM
boomer85's Avatar
boomer85
I have 3.31 and it does great pulling 9300 camper, never tried it on anything else just bought it about 4500 miles ago it was the best deal too and I was thinking along your lines, should I shouldn't I? Perfectly happy I'm at about 1600 rpm at 70 so geared great for milage too
Old May 8, 2016 | 05:04 PM
northernsnooker
Thanks for all the input. I only tow 7-8,000 lb on a regular basis. About 12,000 every once in a while but that's usually 40-50 miles round trip.
Old May 8, 2016 | 05:56 PM
22rimfire's Avatar
22rimfire
You'll be fine with 3:31's. Sooo much torque in the 6.7. My truck came with 18" wheels, and 3:55's because it has the camper pkg.
Old May 8, 2016 | 06:00 PM
roadrunner01's Avatar
roadrunner01
I have the 3.31 and ordered it that way. with 440 hp under the hood I don't have any need for anything lower. I have a 12,000 gvw equipment trailer I tow and constantly have up to 4,000 lbs. in the bed, never an issue. Regens and OC's get stretched out a bit due to lower rpm's, I follow the IOLM and last summer, which is my busy driving time on the highway, I was able to go 10,000 mi. for an OC. UOA came back perfect, as in ok for extended use.
Old May 8, 2016 | 06:10 PM
boomer85's Avatar
boomer85
Thanks
For what its worth you're only looking at 100-150 rpms difference at highway speed. Which may get you half a mile to a mile a gallon better. Not a real game changer but anything helps.get the best deal and smile, according to ford there is no rated towing compasity difference between the two. And both are well suited for what you need
Old May 8, 2016 | 06:18 PM
Painted Horse's Avatar
Painted Horse
If you might ever put 35-37" tires on the truck and still want to tow. Go with the 3:55
The 3:31 and 33-34" tires run just fine.
Mine has the 3:55 gears and I run 295/65R20 tires at 35.1" tall and I tow 13,000lbs almost weekly here in the west with 7-8% grades.
