Excursion towing blues
Old May 8, 2016 | 05:48 AM
jboysdad1's Avatar
jboysdad1
I have a 2002 Excursion 2WD 6.8 that gave me some towing problems first time out. At 55-60 on the highway 15 mph crosswind on light rain asphalt trailer started to fishtail.
I have a 26' travel trailer with sway control and brake controller. I have towed this same rig loaded the same way using a 99 F150 2WD and a 2001 GMC 2500 (non HD) 2WD and never had this problem.
The tires are not 10 ply but are brand new cooper discoverer h/t set at 40 psi cold. The back end dropped about 2 - 2.5 inches with the camper on. The tires did not flatten at all that I could see.
The rig is 5200 lbs loaded so it is way under the tow capacity on the Ex.
I have been checking the Interweb and this seems to be a common problem. I have also seen solutions that cost more than I paid for the truck.
I am considering replacing the Ex rear springs with B code F250 springs and a new set of Monroe Gas Magnum shocks. I have also read a great deal about the Hellwig 7643 Anti Sway bar kit and new shocks.
I would like to retain the current ride height.
For my application what advice can you give.
Thanks in advance.
Old May 8, 2016 | 09:27 AM
wrvond's Avatar
wrvond
The first thing I would do is shift some weight forward. Where is your fresh water tank? Do you normally tow with it empty or full? If it is behind the axle(s) tow with it empty. If it is forward of the axle(s) fill it up and see what it does for your problem.
Of course, the best thing to do is actually weigh the trailer in camping trim and then weigh the tongue. If the tongue weight is less than 10% (13% preferred) of the total weight then you've identified the problem.
Old May 8, 2016 | 08:45 PM
Tom N OH's Avatar
Tom N OH
Freshly paved road? Rutted asphalt from heavy truck traffic? Trailer tire pressures correct? What pressure do the Ex tire sidewalls call for? Door jamb sticker tire pressure? I would think that an Excursion should be on LT rated tires that /should/ be inflated to approx. 65lbs for towing. How's the alignment on the Ex? On the trailer? There are a multitude of things that could have caused the sway. You'll have to eliminate them one by one until you find the one that caused the issue.
Old May 8, 2016 | 10:33 PM
jetjockey99's Avatar
jetjockey99
I think you are marginal at best on load capacity of your tires and 40 PSI is probably not high enough. If your tires are load range D you should be running 65 PSI, if they are load range E which I doubt because you said they are not 10 ply, they should be at 85 PSI. You just don't have a stiff enough sidewall in that tire and if you are not loaded heavily enough on the tongue you will have severe swaying problems. You need to load everything up that you normally pack and go to a scale and get accurate weights. I think the biggest improvement you could make would be load range E tires all the way around.
Old May 8, 2016 | 10:34 PM
fordmerc's Avatar
fordmerc
I wouldn't even want to run those tires at 40 psi without a trailer on an excursion! You are driving a heavy duty truck with a trailer on the back. GET SOME REAL TIRES! You should be running some 10 ply tires at 80 psi.
That is where I would start if I was in your situation.
Let us know how you come out.
Old May 10, 2016 | 07:17 AM
RV_Tech's Avatar
RV_Tech
I would start with wrond's suggestion and get some weights before throwing parts of any kind at the problem.
My two cents,
Steve
Old May 10, 2016 | 08:16 AM
seventyseven250's Avatar
seventyseven250
Get your weights for sure. find a CAT scale near you, spend the ten or twelve bucks, and get your axle weights.
Get Excursion weights without trailer, weights with trailer and no WD bars hooked up, and finally with WD bars adjusted to your "normal" setting.
Post them up if you have troubles figuring out what they mean. Or just search all the threads where folks have mentioned CAT scales, there is some excellent info out there.
Old May 10, 2016 | 10:34 PM
Country_Mouse's Avatar
Country_Mouse
I recommend visiting the Excursion forum on here. These guys know the Ex inside and out.
I have the 6.8 2001 Limited 4x4 with BFG KO'S on them tow with 55/65 psi, Bilsteins front and rear, sway bars stock springs I believe. Our trailer has a 6000# GTWR. Equalizer hitch with built in sway. Ours tows perfectly. I'm sure you'll get this figured out.
Old May 11, 2016 | 04:39 AM
WE3ZS's Avatar
WE3ZS
When the fishtailing started how did you react to it? The best way to safely stop a trailer sway event (hopefully before the big wreck that's about to happen!) is to manually apply the trailer brakes...HARD while maintaining tow vehicle speed at first, then once the trailer brakes are having some effect start to gradually slow down the TV. Keep the trailer brakes activated until you are almost stopped, then be sure to pull over and stop. Don't continue on your way until you do something to help prevent the event from occurring again. Adjust the hitch, check/reset tire pressure, move trailer contents to redistribute weight....something. A properly setup combo should not experience trailer sway.
By "sway control" what exactly do you mean? Are you using a weight distribution hitch? Did you perform a complete re-setup of the WD hitch after changing over to the EXcursion as a tow vehicle? If those pickup had a longer wheelbase than the EX that would explain some of the handling differences.
What load range are the tires if not "E", are they "D"? Many EXs came new with 'D" load range tires and they should work OK with the weight of the EX and your middle weight trailer. How did you come to decide to tow with 40PSI cold tire pressures? Are your tires the stock size of 265/75R16 or larger? What does your door jamb sticker recommend for cold tire pressure?
Yes, your '02 RWD V-10 EX should be rated to tow 10k if I recall correctly. but that's only going to be comfortable if everything is properly setup and balanced.
Excursions came with different spring combinations than similarly equipted pickups of the same vintage and sometimes are a challenge to get properly dialed in for tow duty.
I swapped my Ex stock springs for a set of B codes, but I did mod mine for an additional 4.5" of ride height. New shocks are always good if the old ones are in need of replacement. The Hellwig rear sway bar makes a nice handling improvement on our big wagons, and it may help a little with you towing issues but it shouldn't be "the fix' for them.
Give this thread a good read, it is from the EX part of the forum here (where there is more info on the EX than anywhere else on the planet), it contains a ton of info on ride height changes from various suspension mods done by EX owners. https://www.ford-trucks.com/forums/1...easurents.html
My best advice would be to answer up as many of the above questions asked (in all of the posts above, not just mine) so that we can better make recommendations and get some accurate scale weights of your "ready to travel" setup. Once the group here (and over in the Ex forum where you WILL be posting ) have a chance to see all of that new info we can comment on changes that should help you get all sorted out.
Thanks in advance.
Have faith, your EX should make a fine tow rig with a little tweeking. My '05 4X4 V-10 EX serves as our dedicated tow rig for our 41' 11,000lb TT and it is a super capable and comfortable combo that sees 3 to 5,000 miles a year towing all over the Eastern US.
Old May 12, 2016 | 06:14 AM
Slowpoke Slim's Avatar
Slowpoke Slim
This right here, is solid gold.
Read and heed.
Reps sent.
Dennis Galante
All Things Towing
26
Jun 10, 2018 04:35 PM
Gary Lewis
2015 - 2020 F150
17
Aug 16, 2016 07:57 PM
Soko179
All Things Towing
24
May 23, 2014 07:59 PM
rhc43
15
Jun 24, 2008 10:31 AM
the4by4freek
Jul 29, 2004 08:44 PM
