Dark Gray Interior Plastic Color
Old May 8, 2016 | 01:19 AM
Fordication's Avatar
Fordication
Does anyone have a code or a name for the dark gray interior of a 93 Ford Truck. THanks
Old May 8, 2016 | 01:18 PM
Da_Lariat_Chariot's Avatar
Da_Lariat_Chariot
Usually known as 'charcoal' for the carpet, dash, etc.
Old May 8, 2016 | 06:13 PM
Diesel_Brad's Avatar
Diesel_Brad
The ONLY place I have found for CORRECT color is from LMR
they actually have the paint mixed for FORDS, not some generic one color fits most
https://lmr.com/item/MET-FV19/84-86-...Interior-Paint
YES, I know it says 84-86 but it is correct for the 87-93 ford trucks as well
Old May 9, 2016 | 12:39 AM
Fordication
So you think that gray pictured is the same? I have heard it called Opal Gray as well but I cannot verify that.
Old May 9, 2016 | 04:43 AM
Diesel_Brad
Charcoal is the 87-92 gray
Opal gray is the 94-97
I have Personally used this paint in my bronco
<a href="http://s108.photobucket.com/user/diesel_brad/media/96%20XL%20Bronco/DSC03328_zpscf81fda2.jpg.html" target="_blank"><img src="http://i108.photobucket.com/albums/n29/diesel_brad/96%20XL%20Bronco/DSC03328_zpscf81fda2.jpg" border="0" alt=" photo DSC03328_zpscf81fda2.jpg"/></a>
Old May 13, 2016 | 09:17 PM
Fordication
Well I sent a part to color bond and they said its Granite Gray and based on the Code J, that is indeed Granite. Ordered a can to use next week.
Old May 13, 2016 | 09:27 PM
Diesel_Brad
Good luck with color bond. I personally have never had successes with their stuff
Old May 14, 2016 | 01:03 AM
Fordication
Even if its the right color?
Old May 14, 2016 | 09:19 AM
Diesel_Brad
yes, colors are never right
Old May 14, 2016 | 12:10 PM
Puddy's Avatar
Puddy
Sem Charcol Grey. LMC or your local paint and Body Supply
Old May 24, 2016 | 02:23 PM
Fordication
Well I got the paint and it is granite and it matches. The only problem is that it does not shine like the original. I guess I am going to give LMR a chance.
Sous
Jan 11, 2018 04:36 PM
welove2drive
Oct 27, 2017 06:19 PM
James Argo
2004 - 2008 F150
Sep 11, 2015 04:21 PM
mattjarma
Sep 22, 2014 08:55 PM
cujo8
Paint & Bodywork
Jan 18, 2008 07:59 AM
