glowing rotor
Old May 11, 2016 | 11:16 AM
ifrythings's Avatar
ifrythings
Originally Posted by Leroy Unlisted
the root cause of the problem i believe .. was uneven pad wear .. one side was fatter and the other slimer on each opposite pad .. so the pistons were driving crooked .. this probably lead to binding in the piston bore not helped with torn rubber boots .. so probably i could have avoided .. or extended the time until i would have had to replace the caliper had i installed new pads sooner and thereby returned the piston travel straight ahead..
Thats not the root cause, thats what happens when either the caliper can't move properly or a piston doesnt move right, usually when the caliper can't move you wear one pad down faster then the other (almost always the side that has the piston(s) on it will wear faster). You should replace the caliper if you havent already as to properly rebuild them you have to change the pistions, i have yet to seen one where the rust build up hasn't scorned the seal surface.
Please replace the rotor before it does this
from the excessive heat.
Old May 11, 2016 | 01:52 PM
southern-old-bold's Avatar
southern-old-bold
^^^^^x2 well put
Old May 11, 2016 | 05:06 PM
bashby's Avatar
bashby
I have seen a LOT of rotors on these trucks crack like that.ive been wanting to try cross drilled rotors but keep on putting autozone ones on.
Old May 11, 2016 | 05:29 PM
Leroy Unlisted's Avatar
Leroy Unlisted
Ouch .. that looks pretty bad .. but i can't put a new one .. I just spent the afternoon cutting em' straight ........ i would post a pic but i already put the wheel back on .. but .. i will post a pic of the fre sh cut rotor .. new /pads/caliper when the parts come in the mail ..
Old May 12, 2016 | 11:18 PM
Leroy Unlisted
Okay ..
So about 3:30 in the afternoon i got an email from mister fedex driver ..
Says he left a package at the gate
Rockauto is really on their A game .. i wasn't expecting it soon at all. ..
I'd just placed the order day before yesterday and whoop there it is ..
Let's see what we got >>>
Old May 12, 2016 | 11:32 PM
Leroy Unlisted
One gold plated caliper. .. check ..
Misc. hardware bonus .. check ..
This stuff was on clearance so .. the included extras >
Mostly flaking off 'gold' bling..
And 5 years expired pad grease. ..
Luckily i have grease .. bacon .. chicken. .& automotive .. so .. no biggie
And i don't care if it stays shiny. ..
actually it looks a bit to0 blingy so i hope it falls off and develops a nice rust patina ..
>> THE PATIENT IS PREPED FOR SURGERY DOCTOR >>
¤¤☆¤ okay let's do this >
Old May 12, 2016 | 11:47 PM
Leroy Unlisted
& here she is wearing new pads in them shoes ..
The pads look real cheap .. but they were
Hopefully they don't suck but i think i got swapped out **** hu ners
In place of my 5 dollar clearance Wagners .. but ..
The metal part is also shiny & whooptie doo .. i'll keep an eye on em' and if they wear fast i'll get better ones later ..
The passenger side rotor + caliper are newer and had been previously replaced. .. still n' good shape >>>
mayor
May 12, 2013 12:43 PM
brian931
1983 - 2012 Ranger & B-Series
May 31, 2007 08:41 PM
Pungo
Mar 17, 2005 06:20 PM
RhinoVirus
Feb 28, 2005 07:35 AM
ThePheonixx2
Sep 16, 2003 09:40 PM
