Intake Deep Thump
Old May 13, 2016 | 10:08 AM
navistarnut's Avatar
navistarnut
Could a guy get a bore scope down in there? Not sure you would get much more than a slight profile of the lifter lobe but you should be able to see the cam lobe fairly well? Guessing the damage would be somewhat mutual to both surfaces to some degree.
Just shooting from the hip on this.
Old May 13, 2016 | 10:42 PM
run6.0run's Avatar
run6.0run
Pull the oil filter and put a magnet all around in the bottom. No metal,,,, lifters are good.
Old May 13, 2016 | 11:03 PM
BLADE35's Avatar
BLADE35
There you go Simple
seams like the Oil Pan Drain plug has a Magnet captive in it as well
Old Sep 8, 2016 | 11:50 PM
rossterman's Avatar
rossterman
Did you ever determine the cause of the noise?
bkyota
6.7L Power Stroke Diesel
59
Dec 22, 2018 11:51 AM
Macrobb
Sep 29, 2015 09:13 PM
pkorrupted
Sep 15, 2009 12:12 AM
Firefighter 1406
Jun 11, 2008 07:56 AM
Country4.2
3.8 & 4.2L V6
Jan 16, 2005 08:42 PM
