transmission
Old May 8, 2016 | 07:27 PM
Mark Kovalsky's Avatar
Mark Kovalsky
Frmr Ford Trans Engr
Originally Posted by Macrobb
I... think you are both agreeing with each other here...
That was my point - we are agreeing. This trans is toast. Even with no vacuum reverse would work. But this trans doesn't have reverse. So fixing the vacuum, if in fact it's bad, won't fix this trans.
Originally Posted by tjc transport
i would still check the vacuum pump. it would really really suck to have the trans rebuilt only to find it still will not shift properly because the vacuum pump is bad
But how will that fix reverse?
Originally Posted by PlumCrazy7
I agree, put a vacuum gauge on and verify before anything else. A lot of money has been made off of people with a "bad" c6 trans that only has 1st and reverse. A little bit of vacuum line and all is well.
This one DOES NOT HAVE REVERSE!!!!!!!!!!!!!!!!!!
Old May 8, 2016 | 08:18 PM
mattb77's Avatar
mattb77
Just to be clear I do have reverse after the truck warms up about 5 min or so. I appreciate all the replays and will keep u up to date on what I find. I will start by checking lines and pump but I have a transmission that I bought with a 86 I've been parting out so I should be covered either way
Old May 8, 2016 | 09:10 PM
Mark Kovalsky
That says to me the seals in the reverse clutch is old and hardened.
Old May 9, 2016 | 09:35 AM
bashby's Avatar
bashby
Any chance some sort of snake oil will soften them?
Old May 9, 2016 | 12:37 PM
Mark Kovalsky
I've never tried that approach. I don't know if it will work or not.
Old May 9, 2016 | 03:14 PM
southern-old-bold's Avatar
southern-old-bold
When faced with options of fixup fluids I prefer to visit the snake charmer and his shelf of new parts.
Old May 9, 2016 | 03:20 PM
bashby's Avatar
bashby
I am not an additive guy as a rule, even if it did work for a while I'd be expecting it to break down again at an inconvenient time. Might be worth a shot in this case.
Old May 9, 2016 | 03:49 PM
tjc transport's Avatar
tjc transport
i ain't rite
never said it would fix reverse Mark. all i was saying is that low vacuum will make a C6 not shift properly, and extremely low vacuum will make it not shift until you let off the throttle.
if he has a bad vacuum pump, replacing the trans will not fix the shifting problem.
i actually think he has two problems, low vacuum, and bad seals in the reverse circuit.
Old May 9, 2016 | 03:53 PM
tjc transport
i ain't rite
my experience at the body shop with the snake oils is that they do not work. the lucas stop leak works for a little while, but every vehicle that i ever had come in that had snake oils added to the trans needed a trans put in it within a few weeks of adding it.
Old May 9, 2016 | 03:58 PM
Mark Kovalsky
My guess, and I do mean guess, is that he has worn seals in all of the clutches and servos.
TheKirbyMan
18
Jul 21, 2011 10:27 PM
Capone
1978 - 1996 Big Bronco
Jun 24, 2004 11:33 AM
n2music
16
Mar 22, 2004 10:26 PM
superswamper
Offroad & 4x4
Oct 13, 2003 07:31 PM
MattD
Sep 14, 2001 07:54 AM
