Sponsored by: Real Truck
Abs sensor help
Old May 6, 2016 | 11:00 AM
broknsmokey's Avatar
broknsmokey
Abs sensor help
Hey everyone! I recently replaced my abs sensor on my driver side front axle after I broke it trying to grease the hub bearing through the abs hole. Since replacement, start up routine is normal but the light stays on after I start driving. The mechanic out our shop put a code reader on it, said it couldn't read the bearing. So I took everything back apart, cleaned the grease off the sensor with a paper towel and put everything back together and the light still comes back on. I'm not sure exactly what grease I used, same heavy duty grease I use on my tractor. What's my next step? Should I keep taking it apart and cleaning it? Will that fix it? Thanks for the input.
BTW the truck is a 2001 7.3 with 280k with some mild mods
Apocalypse
Jun 12, 2017 07:00 PM
broknsmokey
May 7, 2016 01:04 PM
Capt.Schenk
Jul 25, 2012 08:30 PM
chops1987
1983 - 2012 Ranger & B-Series
Feb 11, 2009 05:31 PM
