'67 F100 352 to 390 cooling issue
Here's the situation:
I just installed a rebuilt 390 in place of the tired 352 in my F100, nothing wild just a stocker (for now ) I'm using the stock 2-core rad with no shroud, 195 thermostat, and a 50/50 mix of antifreeze/water.
Everything's going well, breaking in the cam for about 30mins at 2500rpm, and the antifreeze starts to boil in the rad! So here I sit pondering my options.
1. New 4-core rad, but I don't have $600 right now.
2. Try to backflush the rad and hope that solves the problem until I can try option #1.
Thermostat was installed correctly, upper and lower rad hoses are new with a spring in the lower, so what gives? I realize that engine break in generates more heat, and the lack of a shroud isn't helping but I can't believe a 390 generates that much more heat than a 352.
Any advice you guys/gals can provide would be more than welcome.
Maybe you got a tight motor, they generate a lot of heat before breaking in. Do you know what the overbore is? Check the timing and advance too. The 2-core rad has got to go, you need at least a 3-core and a shroud. Did you test the stat in boiling water? Maybe it's sticking or opening late.
Barry
Barry
I replaced the stat to be sure, checked the timing and found the advance canister was shot. Waiting for a new one, hopefully tomorrow.
I know the 2 core needs replacing, and for a $100 more I'll take a 4-core over the 3, but right now it might as well be a $10,000 'cause I still don't have it. The rad is in the works for the next couple of months.
I'm crossing my fingers that the back flush of the 2-core stocker will at least make it driveable until I can get the new rad. I miss my truck!
Anybody else running a 390 with a 2-core rad? Do I have any chance at all?
A shroud is mandatory, especially sitting at idle in traffic. I just replaced my radiator, hoses, etc on my 390 and it stays nice and cool now.
You can pickup a 3-core radiator for $184.11 from http://www.radiatorbarn.com. I didn't see the F-100 in their menu for '67 but they have a radiator for a '68 F-100 with a 390. I don't know if there is any difference between the two years, though. I got a 3-core from them and it fit like the original.
Also, I would check to see if you're running too lean. That can bring the temp up too.
The shroud is a must, and you may find you can even get by with the radiator that you have. A healthy engine makes alot more heat than a tired one, also more cubic inches make more heat. I don't think you would ever need a 4 core if you purchase new. A 3 should do fine. I put a new 3 core on a 72 with a 302 and electric fan. It would have to idle for at least 1/2 hour in 70 degree weather for the fan to even come on.
My truck was a 3row with no shroud. When i holed the original rad, I put in a Modine 4 row. i believe it was about $250. I now have a 390, 4 row, and no shroud. I don't have overheating problems, but I'm not breaking in a new motor either. Put a box fan infront of the rad. it doesn't get enough airflow from the engine fan alone when sitting still turning 2,000 for 30 min.
One thing I haven't seen mentioned here (maybe I overlooked it)- change your radiator cap. When they become weak and don't allow pressure to build in the system, it will boil over. This should buy you a little time until you can get a larger radiator- and I do recommend you getting one AND a shroud. It'll probably do better sitting still on a cool day with the new cap but it will overheat if you get stuck in traffic.
Joe
Joe
Thanks for the advice and info everyone.
The stock 2-core didn't handle the reverse flush very well, but after 36 years I'm not surprised so the new 4-core is on order. Oh well, at least with the rad out, I can swap in that new support and inner fenders that have been cluttering up my workbench.
Once again, thanks!
Once again, thanks!
Eh1992xlt
02-04-2016 10:34 AM
waituntilthebeep
42
10-13-2015 04:39 PM
BYOBoat
07-22-2015 11:07 PM
sdetweil
186
05-25-2010 04:18 PM
