1978 - 1996 Big Bronco
Part Identification/Info
Old May 5, 2016 | 10:37 AM
masseysbronco's Avatar
masseysbronco
What exactly is this thing that's connected to the smog pump? Some kind of air filter? I need to free up some space around my batteries for a low voltage disconnect and a battery isolater; wondering if I can just remove this thing and put some valve cover filters or something on the end of the 2 rubber tubes feeding it. My air pump is currently still in use, but I'll probably replace it with an on-board air compressor someday since I've read the smog pump makes no real difference on emissions anyway.
Old May 7, 2016 | 02:58 PM
Encho's Avatar
Encho
The Southernmost Mod
The images aren't showing, so we can't help you bud.
Old May 11, 2016 | 06:11 PM
Black Ford XLT's Avatar
Black Ford XLT
Massey try retaking or reposting the pictures , on the air pump there is valves associated (inline) that run from the pump to the air injection lines. Since I have mine out I can look at it and give you the Ford numbers .Good luck TR
Old May 11, 2016 | 06:59 PM
masseysbronco
How about now?
Funkykolemedina
34
May 6, 2021 04:03 AM
Urgrosh
Mar 23, 2019 03:32 AM
73effie
Nov 23, 2015 07:55 AM
truknut1972
Aug 23, 2008 10:09 PM
870
Oct 7, 2007 01:34 AM
