Radiator core support ID
Old May 4, 2016 | 02:11 PM
Brian1971f100's Avatar
Brian1971f100
I think I got the shaft. Some years back I purchased a radiator core support off ebay. It was supposed to fit my 71 f100, it looked right or so I thought. I recently started working on my truck after 17 years of collecting dust. I started cleaning up my rad core and found some numbers, but it is possible that its from a '73 to '78. Anyone out there help me out with this.
Old May 4, 2016 | 02:35 PM
RichS2659's Avatar
RichS2659
Sticker is from a 76 as referenced by the D6.
Old May 4, 2016 | 04:07 PM
Randle's Avatar
Randle
The only thing you have to do to install a 73-79 core support on a bump is drill two upper and two lower grille support holes. Everything else will bolt right up. I have a 73 on my 70 now.
Old May 4, 2016 | 05:09 PM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
1967/72 F100/350: TWO different radiator supports.
One was only used with the Super Cooling radiator as it has a larger opening radius.
The sticker with D6BE-8057-AA printed on it...has nothing to do with a radiator support.
It's the ID Engineering number for a positive battery cable.
Old May 4, 2016 | 06:28 PM
ultraranger's Avatar
ultraranger
It's the ID Engineering number for a positive battery cable .
Granted, I'm not a Ford service parts guy but, doesn't the 8000-8499 basic part number series fall under the catagorization of "Radiator and Grille" parts? A radiator core support would seem to definitely fall under, per Ford, "parts which qualify by functional area" but, the number seems to be in reference to the coolant instructions sticker itself, that's on the core support.
This is what I'm referenced to when I search that number.
1973-79 Coolant Caution Decal-Broncograveyard.com
Old May 4, 2016 | 06:46 PM
NumberDummy
When I looked under 8057 in the parts catalog, I saw no basic number of such. But in the Master Cross Reference Catalog, I found several 8057's that cross to 14300 positive battery cables.
However, thinking about it, D6BE-8057-AA may be the ID number for the sticker itself.
Radiator supports are basic part number 16138
Old May 4, 2016 | 08:48 PM
D & D's Avatar
D & D
For my 68, I had to drill a hole for the hood latch to be moved and two holes per inner fender. But yeah, minor work to use the later model radiator support.
Old May 5, 2016 | 06:51 AM
Brian1971f100
This is all good news. I dug out my original core support and will compare the two too make sure. Thanks for the help.
Old May 5, 2016 | 06:58 AM
Randle's Avatar
Randle
You are right Sir, my Old Timers kicked in I guess.
johnny19
Oct 29, 2018 09:14 PM
otnot
Oct 16, 2018 05:36 PM
gumby 1
Jul 30, 2017 09:22 AM
Daddy's 61 unibody
May 30, 2004 11:19 PM
GeneStoner
Jan 20, 2003 07:49 AM
