Aerostar Ford Aerostar
PROJECT: Front Spring Replacement AWD
Old Aug 16, 2019 | 11:26 AM
xlt4wd90's Avatar
xlt4wd90
I don't think anybody makes a coil-assisted damper for the front of an AWD Aerostar. I think there may not be enough room for such a configuration; the damper body is really close to part of the cross member.
Old Aug 16, 2019 | 12:03 PM
gipester's Avatar
gipester
You're probably right. I got lucky and found an AWD aerostar in a local salvage yard, so I'm pulling the springs from that. But I sure would like to find a better solution. What a pain in the butt this rebuild has become!
Old Aug 16, 2019 | 02:41 PM
Car Guy's Avatar
Car Guy
Check carefully for broken coils on the top and bottom. VERY common Ford trait and the Aerostar is no exception. Especially if you live in a region where rusting is common. Ford had many recalls for this over the years. One coil on each of mine is broken and this area is not what I’d consider ‘rusty’. The broken coils is why I haven’t replaced the control arm bushings yet.
Old Aug 16, 2019 | 04:09 PM
gipester's Avatar
gipester
Thanks. I definitely will. That's why I have to replace one of the ones I have. They weren't sagging, but one was broken. If I can at least find one good one, I'll at least be able to drive it.
coolfeet
74
May 8, 2024 08:15 AM
login6696
Jul 30, 2018 10:59 AM
NICKSAN
Nov 7, 2017 09:24 PM
DeathRangerofDeath
Mar 5, 2016 04:58 PM
Emilime75
Aerostar
Nov 25, 2009 05:55 PM
