Time for new fluids
Old Jan 26, 2002 | 01:28 PM
MustangGT221's Avatar
MustangGT221
Time for new fluids
I Posted this in the oil and lube section but got no replies. I've got 105,000 mi on my 95 4.9L f-150 and its alil past due on some new fluids. The Coolant is all set but i need to replace the trans and differential fluid. I've got a mazda 5 speed and 8.8 inch rear with Traction Lok limited slip. I know that needs the additive but what kind of lube do you recommend for the rear and what additive do you recommend? I've heard that the mazda uses ATF, how come and what kind should i use?
Old Jan 26, 2002 | 02:31 PM
PAUL_2's Avatar
PAUL_2
Time for new fluids
The rear end uses 80W90 & if you have the limited slip then you need to add a 4 Oz bottle of whats called Friction Modifier , Ford has it as do most auto parts stores . The M5OD uses Dexron , Whatever the newest is , Dexron III I believe . Check your owners manual on the rear axle lube , it may give a range of weights to use , But 75W or 80W will do fine .
Old Jan 26, 2002 | 04:43 PM
ryan95f150's Avatar
ryan95f150
Post Time for new fluids
CountryBumkin
Jun 13, 2012 09:07 AM
piersol
Dec 25, 2009 09:49 AM
brian931
1983 - 2012 Ranger & B-Series
Apr 8, 2009 07:16 AM
tndiesel
21
Aug 5, 2008 01:29 PM
redtopper
Jul 9, 2002 05:19 PM
