Battery disconnect
Old May 2, 2016 | 12:19 PM
hooler1's Avatar
hooler1
Battery disconnect
My 56 still has the original wiring harness in it
. I drive it 2 or 3 times a week and always disconnect the battery when I am done. My battery is in the stock location under the trap door on the passenger side floor pan. Pulling back the carpet and constantly opening and closing this door and connecting/disconnecting the battery is getting old. I am kicking around the idea of adding another starter relay in series with the one that is installed in it now, then adding a hidden switch in the cab that will power on the new relay thus connecting the battery and ignition voltage to the original starter relay. When done driving you simply turn the switch off. That will cut off the power for everything making me worry less. Anybody done this or have any thoughts?
Old May 2, 2016 | 01:34 PM
fking1's Avatar
fking1
If you drive 2 or 3 times a week do not see a need to disconnect the battery IMO.
Old May 2, 2016 | 01:53 PM
ALBUQ F-1's Avatar
ALBUQ F-1
I routinely leave mine for a month without starting it. No problems. Are you concerned about a short lighting things off?
I don't think the solenoid idea will work, those just aren't made for continuous duty. There are plenty of bulkhead mount disconnect switches you could put on the floor right above the battery.
Old May 2, 2016 | 02:29 PM
Nicholas+'s Avatar
Nicholas+
Why do you disconnect the battery after you drive it?
Old May 2, 2016 | 03:07 PM
raytasch's Avatar
raytasch
Believe Nothing
"My 56 still has the original wiring harness in it"
This from the OP./\
I've seen a few and driven a few older vehicles where I would feel more comfortable disconnecting the battery when vacating the vehicle.
Old May 2, 2016 | 03:44 PM
CBeav's Avatar
CBeav
Are your concerns based on safety, parasitic draw or theft prevention?
Old May 2, 2016 | 03:55 PM
Tedster9's Avatar
Tedster9
Originally Posted by raytasch
"My 56 still has the original wiring harness in it" This from the OP./\ I've seen a few and driven a few older vehicles where I would feel more comfortable disconnecting the battery when vacating the vehicle.
Especially in an attached garage, say. Good preventive strategy. The battery shutoff switches are mostly junk at the retail level. Good ones designed to carry the amperage are close to a C note.
Old May 2, 2016 | 04:17 PM
bigwin56f100's Avatar
bigwin56f100
I have a batt disconnect connected on the ground side with a removable key. Use it for theft prevention and fire prevention.
Old May 2, 2016 | 08:42 PM
hooler1's Avatar
hooler1
[QUOTE=ALBUQ F-1;16254007]I routinely leave mine for a month without starting it. No problems. Are you concerned about a short lighting things off?
I don't think the solenoid idea will work, those just aren't made for continuous duty. There are plenty of bulkhead mount disconnect switches you could put on the floor right above the battery.[
Yes sir. I worry about the lack of fuse controlled protection in the various beach circuits in the truck.
Old May 2, 2016 | 08:46 PM
hooler1's Avatar
hooler1
It sits by itself in a storage unit. So if it has an electrical problem and starts cooking, no one's around to know.
Old May 2, 2016 | 08:47 PM
hooler1's Avatar
hooler1
Yes, it's a safety concern.
Old May 2, 2016 | 08:56 PM
ALBUQ F-1's Avatar
ALBUQ F-1
How about one of these?
Moroso Battery Disconnect Switches 74101 - Free Shipping on Orders Over $99 at Summit Racing
Old May 2, 2016 | 08:57 PM
artscott61's Avatar
artscott61
Veteran: Navy
PO put one on my truck and yes I do use it from time to time if we are going to be gone for awhile.
Old May 2, 2016 | 09:38 PM
Jules The Great's Avatar
Jules The Great
Old May 2, 2016 | 10:58 PM
eman92082's Avatar
eman92082
I'm using the Painless 50710 which was $80 bones. With my Batteries mounted under the body, it's really convenient.
