Replacement flareside tail lights?
Old May 1, 2016 | 10:39 PM
uniwagon's Avatar
uniwagon
Hi,both of my tail lights fell apart while cleaning 30+ year old plastic.Pass side not a problem,but the drivers side factory has no plate light. all of the replacements do.My plate is below the bumper,factory.Are there any housings with out the plate light with 3 studs not 2?Or has anybody just painted the clear plastic for the unused light?
Chris
Old May 2, 2016 | 04:07 AM
FuzzFace2's Avatar
FuzzFace2
There was a post not long ago someone wanting tail lights and needing the side lights on them.
Do a search as there were links posted just don't remember about the plate light.
As you said may need to paint over it.
When you find something post back as I am sure it will help others.
Dave ----
Old May 2, 2016 | 06:12 AM
FuzzFace2's Avatar
FuzzFace2
https://www.ford-trucks.com/forums/1427929-flareside-tail-light-source.html
Dave - - - -
Old May 2, 2016 | 03:38 PM
4x4man514's Avatar
4x4man514
Grote does make the light, 52802 and 52812. They don't have ford connectors but are 3 stud. That's what I bought and outside of the connections they are spot on replacements.
Old May 2, 2016 | 08:14 PM
uniwagon's Avatar
uniwagon
Hello,after calling everywhere and having no luck,a week to get,don't know what I am talking about,cost to much,no I don't want trailer lights ect..........I just when for a ride 30 miles away to an all truck salvage yard that I go to often.walk in tell them what you want and they find a get it.Turns out Jeep Wrangler lights all the way up to early 2000s are the same I got them from a 04 Jeep(50$) I just have to lengthen the wires and I painted the plate light black. I also ordered a new key parts flareside rear bumper from Jegs today.
Chris
Old May 2, 2016 | 08:18 PM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
Chris
D7TZ-13435-B .. Tail Lamp Body (no lens or gasket) / Obsolete ~ No Ford dealer or obsolete parts vendor has any.
1977/87 Flareside.
EOTZ-13405-B .. Left Flareside Tail Lamp Assy / Obsolete ~ No Ford dealer or obsolete parts vendor has any.
1980/87 Flareside.
Old May 2, 2016 | 10:40 PM
Rusty_S's Avatar
Rusty_S
I could have sworn LMC had theses assemblies listed
They only have the right side.
36-4439
NPD Link also only sells the right side.
Wonder why only the right side is being made and not the left. I really need the left as my side marker I keep having to glue it on and its a matter of time before it falls off on the road.
Old May 3, 2016 | 02:41 PM
4x4man514's Avatar
4x4man514
I never could find the left side. But outside of changing connections you won't be disappointed with the grote lights I listed earlier.
Old May 25, 2016 | 07:04 PM
dads1977's Avatar
dads1977
Chris
Chris,
I am in the same predicament as you...
In search of replacement tail lights for my '77 flair side.
and I saw a new jeep that has a VERY similar tail light assy.
now I haven't gone and talked to my local jeep dealer but in looking on line
it appears you could order one from jc witney for around $30.00 to $35.00
BUT.....I am un sure of the mounting screws/bolts configuration
planning on going by and looking at one tomorrow after work....
as far as sealing off the clear part on my GROTES (now this my sound red-neck-ish) I simply covered it from the inside with metal tape for higher reflectiveness
Recurve
May 9, 2016 07:33 AM
Adam Woolridge
Nov 7, 2015 05:58 PM
LOADED 06 PSD
Dec 27, 2008 04:44 PM
cwemg
Aftermarket Products
Jan 24, 2002 06:30 PM
cwemg
Nov 24, 2001 10:14 AM
