Large Truck My truck is bigger than yours. The forum for 2+ ton trucks (all years), COE's, Louisville's, Big-Job's etc.
What am I getting into???
Old May 1, 2016 | 10:16 PM
lance65's Avatar
lance65
I am about to take possession of a 1970 F600 with a 14' box (Ryder maybe). It has the 300 in it. What am I getting into? Is this a headache that I dont want, or are there upgrades that can/will be somewhat affordable? Things like brakes, tires, axles??/
Will F-SuperDuty axles fit this thing? or is this a beast that I dont want to try and tackle?
Old May 1, 2016 | 10:49 PM
85e150's Avatar
85e150
What are you trying to do with it? Does it run?
An axle change to later axles can be done, but you will be on your own for figuring out what fits, fitting it, and dealing with driveshafts etc.
One thing about the later axles would be the use of lower profile tires on most of them. 19.5s, vs. the 20" high profile tube type tires on it. You might have 4" or better difference in diameter.
"Affordable" depends on what you can afford. Tires in the existing size are probably $200 a copy plus tubes and flaps, and if they are locking ring wheels, you will need to find someone who will work on them.
If you change axles you will answer the brake issue. For the oem brakes, shoes and internal parts can be had, but there are no new drums available.
Sycostang67
All Things Towing
Aug 8, 2009 11:38 AM
Mudman
Offroad & 4x4
Nov 27, 2006 10:12 PM
zinga
Jun 27, 2005 06:38 PM
rebelbob
Offroad & 4x4
26
Jun 18, 2003 11:59 AM
