Sponsored by: Kumho
52" tires??
Old Jun 26, 2005 | 07:58 PM
zinga's Avatar
zinga
52" tires??
Anyone have a clue if i could fit 52" tires under an 83?? If so, how much lift would that require.... I can't begin to figure it out.... If it's at all possible i'd love to do it... Thanks for any input..
Old Jun 26, 2005 | 08:00 PM
ford390gashog's Avatar
ford390gashog
You might be a redneck if, you want to put 52'' tires on your truck. JK
Old Jun 26, 2005 | 08:59 PM
yaki69's Avatar
yaki69
im no expert on lifts but i do know a few things. 1, you're gonna have to have a massive 4 link setup,and prolly gonna have to drop the transfer case... 2. and those stock axle aint gonna hold up them tires. if you wanna do it right and not cheap out. go with a rockwell 2 1/2 ton axle. the old deuce and a half truck axles. they can hold up to the weight of those tires. you gonna use this as a show truck? or what?
Old Jun 26, 2005 | 09:04 PM
zinga's Avatar
zinga
Yes, i am a redneck...lol
Ya think dana 60s will run these tires?? Thats acutally what i have.. If i can't use them then 52's are out... I'm expecting alot of fabrication.. Not a show truck.. Just came across these tires and thought they would be awesome on my truck.... I would imagine you don't come across those 2.5 ton axles very easy huh??
Old Jun 26, 2005 | 09:09 PM
yaki69's Avatar
yaki69
they arent that hard ot find. ads in all 4 wheel drive mags. they run about $900-1500 a peice. but last forever, and made to your specs. dana 60's? i wouldnt go over a 38. and thats pushing it. id personally go wiht a built 9 inch in the rear, and a modified 9 inch up front. they are more capable of holding up a bigger tire, with less chance of snapping.
Old Jun 27, 2005 | 12:24 PM
andym's Avatar
andym
You can go a lot bigger than 38's with Dana 60s, but not to 52". Although it really depends on how you're going to drive it. If you're going offroad with it in the mud, doing jumps, rock crawling, etc. then you'll break a D60 within about two minutes with those tires. If it's an asphalt monster, then you'll be ok.
Old Jun 27, 2005 | 12:56 PM
hatemakings/n's Avatar
hatemakings/n
try a search for chuckstrucks. He does 2 1/2 ton and larger axle swaps and runs huge tires. He also has a Florida mud pit to test stuff in. He did a school bus with 5 ton axles and 66" terra flex tires pretty cool for a school bus.
Old Jun 27, 2005 | 06:38 PM
zinga's Avatar
zinga
Thanks for all the info guys... I'm gonna try to diggin' up a set of 2.5 ton axles and see what i can make.... I do want this for off road... I have a pavement pounder... My wifes car... lol
arkredneck
Jun 27, 2011 06:15 PM
fordtruck52
Jun 5, 2011 12:21 PM
52 panel
16
Nov 13, 2006 02:23 PM
mich52
Oct 12, 2004 08:07 PM
roland_rathay
Sep 20, 2000 08:35 PM
