I have a 2003 F-250 2wdthat I want to put a 2 inch front leveling kit on. What all does this consist of? Is it as easy as just putting the spacers under the springs? Thanks in advance for any help!
I just did this mod and after putting the spacers under the springs your steering geometry is wacked out. The camber bushing will need changed and you will need to clearance the spindle for them to fit. Your toe will need adjustment also. Search and you will find a thread showing how.
The look makes the truck finally look right,always hated the rake!
