First Gear Problem
Old Apr 28, 2016 | 12:27 PM
Spparky82's Avatar
Spparky82
First Gear Problem
Hi, I have a 1968 F250 with a 360 3 speed on the tree and last year the truck barely got in first gear, sometimes it would go in and now it's grinding the fly wheel. Is that because the linkage has to be adjusted? Or is my first gear is gone?... If it's adjustment is all that under the truck or in the column? The truck shifts into all other gear fine only fort is the problem? Clutch pedal feels good.
Thanks
Old Apr 28, 2016 | 02:29 PM
rustywheel68's Avatar
rustywheel68
you may need to adjust the shift rods. they're threaded along the side of the transmission.
Old Apr 28, 2016 | 03:29 PM
351Cleveland C4's Avatar
351Cleveland C4
Is your clutch adjusted properly?
Old Apr 28, 2016 | 03:56 PM
Brian1971f100's Avatar
Brian1971f100
Does it shift into gear when the truck is off? If it does then you have to (A) adjust clutch. (B) inspect clutch linkage for damage. (c) replace clutch and pressure plate.
Also you should check out cab mounts, they can affect your clutch adjustment.
Old Apr 28, 2016 | 04:12 PM
jowilker's Avatar
jowilker
Sounds like a clutch issue to me.
John
Old Apr 28, 2016 | 04:17 PM
Spparky82's Avatar
Spparky82
It shifts into all the other gears fine that is why I am ruling out the clutch,I think
Old Apr 28, 2016 | 06:25 PM
orich's Avatar
orich
It could be the pivot clutch arm bracket that's a common problem for many of these old trucks.
If the clutch pedal keeps getting lower to engage the clutch not to grind more noticeable when stopped trying to put it into gear 1st or into reverse.
But I think it's time you buy a manual so you can learn to do some of the eases stuff.
Crawl under that truck and have a look at the clutch linkage and find a threaded adjuster..
Orich
Old Apr 28, 2016 | 08:59 PM
RichS2659's Avatar
RichS2659
Check the bushings on the shift rods as the one for the first and reverse shift could have cracked and fallen out.
davem77f150
Apr 19, 2016 01:18 PM
RhinoScores
1983 - 2012 Ranger & B-Series
Nov 30, 2006 10:10 PM
sancochojoe
22
Jul 19, 2006 07:36 AM
harley_52
Mar 5, 2003 10:25 PM
lkt
Jan 14, 2003 12:50 PM
