2015 + Expedition & Navigator 2015 + Ford Expedition and Lincoln Navigator
Tow package rides rough
Old May 2, 2016 | 06:27 PM
LokiWolf's Avatar
LokiWolf
Originally Posted by dlcorbett
I just looked it up, it is optional on xlts
Hence why I said it was an option...just went through the process of buying a 2015, and have done a ton of homework!
It is comparable in the sense that its a higher end option on the vehicle which purpose is to increase ride comfort for different situations. i honestly think this should be an option on the smaller wheels as well.
I agree, would have taken it as an option, but didn't want the 22's. I think it has to do with tuning on the shocks. The tuned the system to work with the 22's, to give a better ride, but have the fancy wheels.
Old May 7, 2016 | 01:13 PM
cre8fun's Avatar
cre8fun
to the OP, from 20105 on the tow package does not change the suspension - so the source of your different ride is not the tow package. the heavy tow package consists of wiring, trans cooler, bigger radiator, heavy duty flashers, etc.. springs and shocks are not dependent on tow package. Source (fleet ford RV&trailer two guide)
Old May 7, 2016 | 01:49 PM
YoGeorge's Avatar
YoGeorge
I will return to tires especially if the suspensions are the same. If your Expy has the Hankooks or some other brand, move to Michelins (stay with P rated tires) and I am guessing you will note a significant difference on the small "busy" kinds of bumps like pavement expansion strips and cracks. If you have doubts, read Tire Rack, Discount Tire, or Consumer Reports for ride quality ratings on tires.
The Premier A/S and Latitude Tours are both designed for a luxurious ride. The LTX M/S2's (or Defender LTX M/S) are probably a bit less smooth but I love these tires and would put them on any truck or SUV if there was a size that would fit.
Good luck,
George
Old Jun 2, 2016 | 06:30 PM
glockholiday's Avatar
glockholiday
I'd say it's the 22's. They ride WAY WORSE than 18's wheels.
Old Jun 2, 2016 | 06:42 PM
LokiWolf's Avatar
LokiWolf
Did you read the thread? The OP has 18's.
ATX SD
2015 - 2020 F150
38
Jun 6, 2018 04:53 PM
mike91911
All Things Towing
Feb 27, 2009 04:22 PM
rmalottwtes30
Sep 16, 2008 06:41 AM
kevin.ford-trucks
Sep 7, 2007 07:12 AM
va150
All Things Towing
Jan 30, 2007 12:49 PM
