Catalytic Convertor failure
Old May 1, 2016 | 07:26 PM
85e150's Avatar
85e150
Originally Posted by claudeyounan
so i think using mufflers with x pipes will solve it but still the engine light will stay on right?
Without the "proper" signal from the sensor downwind of the cat, your engine will not run right. Might go into a limp mode, might run rich or lean.
Old May 1, 2016 | 07:28 PM
unibody62's Avatar
unibody62
Originally Posted by Tom
Eastern Catalytic is a good option as well, they're one of the larger aftermarket companies that makes direct-fit cats. But NONE of them are a good option until you figure out why yours went bad.
I suppose it might be good to check a few things, but CC 's do go bad just like other parts. I read the piece from Eastern about failure and many of the causes mentioned would trigger a code anyways. I personally had a failure under warranty and that was 60k miles ago with no other problems with the Cat. Apparently, checking the old cat would help you determine if there was another cause.
Old May 2, 2016 | 01:41 PM
claudeyounan's Avatar
claudeyounan
Thank you Tom and everyone else. You have been a lot helpful. I shall proceed with your advice.
passthru69
Apr 18, 2010 05:16 PM
CNC
Jan 31, 2010 04:50 AM
89CrewCab
Oct 22, 2008 07:12 PM
JRT32615
3.8 & 4.2L V6
Feb 12, 2007 07:16 PM
Racecarhauler
Apr 10, 2006 07:41 AM
