2002 Ford Ranger
Old Apr 28, 2016 | 12:10 AM
rlay302's Avatar
rlay302
2002 Ford Ranger
How do you change the rear axle bearings on a 2002 Ford Edge Ranger pickup?
Old Apr 28, 2016 | 02:19 PM
exranger06's Avatar
exranger06
I assume you're talking about the axle bearings near the wheels? If so, you need to first remove the axle shafts. Here's a useful video on how to do that:
Then, you use a slide hammer and an axle bearing puller to remove the bearings. You can usually rent these tools at an auto parts store. Watch this video on how to change out the bearings:
In the video, he uses a pry bar to first remove the seal, and then the puller to remove the bearing, but you can actually remove both at the same time using just the puller.
Old Apr 28, 2016 | 02:25 PM
exranger06's Avatar
exranger06
Oh, and when you're at the part store buying new bearings and seals, tell them you have a 7.5" axle. If you tell them you have the 8.8" axle, you're going to get the wrong parts (even if you have an 8.8 axle). I'm not sure which axle your truck has, but I do know it's either the 7.5" or the 8.8 with 28 spline shafts, and both of those axles use the same bearings and seals. So like I said, just get parts for the 7.5 and you'll get the right stuff.
Old Apr 28, 2016 | 11:40 PM
rlay302's Avatar
rlay302
Thanks for the replies, I will aslo be changing the fronts so, any help would be very nice. This truck is an edge 4 x 4.
hmfinc
1997 - 2003 F150
13
Aug 7, 2025 03:50 PM
enriched&beyound
24
Jun 12, 2017 07:15 PM
Darksideforge
1997 - 2003 F150
15
Mar 29, 2017 09:07 AM
wildjon300ci
Jan 21, 2003 06:17 PM
dunebuggys
May 7, 2000 05:05 PM
