It died
Old Apr 26, 2016 | 05:06 PM
Jeff heine's Avatar
Jeff heine
It died
Sitting idling for a few minutes started to run rough, like running out of diesel. Then it cleared up. Left the job and started again. It died and won't start.
Old Apr 26, 2016 | 05:10 PM
robbyriot's Avatar
robbyriot
Sounds maybe like a hpop
Old Apr 26, 2016 | 05:36 PM
z31freakify's Avatar
z31freakify
Check the tin nut on the ipr to see if its still there.
Old Apr 26, 2016 | 06:46 PM
Jeff heine's Avatar
Jeff heine
It tries to start, like when you've run out of fuel. Would the hpop or ipr do that?
Old Apr 26, 2016 | 09:43 PM
robbyriot's Avatar
robbyriot
Could be possible. Definitely sounds like a fueling issue somewhere. Could even be something as simple as a filter.
I deal mostly with big diesels. I just recently got a 7.3 so I'm taking most of it from my work experience. A lot of cat engines use to use the same style injectors. And when injector pumps went it was similar to what you have going on. But I've seen dirty fuel filters do the same also.
Old Apr 26, 2016 | 10:30 PM
fordpride's Avatar
fordpride
Check the fuel psi, tin nut on IPR, and for burnt uvch
Old Apr 26, 2016 | 10:34 PM
z31freakify
The HPOP on these trucks are pretty much bullet proof they just dont die.
Old Apr 27, 2016 | 12:14 AM
oldbird1965's Avatar
oldbird1965
Agree with Adam, the hpop will go gradual but not all of a sudden. I vote for uvch or cps.
Old Apr 27, 2016 | 07:44 PM
Jeff heine's Avatar
Jeff heine
I removed the fuel filter. Diesel was about halfway up the canister. Had someone turn it over. Level did not rise but it did bubble. Added five gallons of fuel, just in case screen had fallen off, that happened before. Still level did not rise. I'm thinking fuel pump?? It about 5 years old and Ive put 250-300k on it since I changed the pump. Ive heard they have two pumps, is that true. I only know of the one behind the filter canister
Old Apr 28, 2016 | 09:14 AM
farmert's Avatar
farmert
There is only 1 fuel pump on these trucks, but it is a two stage pump with a low side to the filter, then a high side to the injectors. Sounds like it is time for a replacement.
Old Apr 28, 2016 | 04:19 PM
Jeff heine's Avatar
Jeff heine
Called ford. They needed the vin#, five pumps available. The one for mine is 517.00
Oriellys shows one pump for my truck 99.99 made by Precision. What would yall do???
Old Apr 28, 2016 | 04:38 PM
444dieselrod's Avatar
444dieselrod
Screw Ford, get the one from the parts store.
5 pumps!!!! What goon looked that up, they only had 1 until the 97's, then it was 2 cuz of the Cali trucks.
Old Apr 28, 2016 | 05:56 PM
Jarrett Campbell's Avatar
Jarrett Campbell
5 in stock?
Old Apr 28, 2016 | 07:42 PM
Jeff heine's Avatar
Jeff heine
Not five on one truck I could be one of 5
Old Apr 28, 2016 | 08:11 PM
robbyriot's Avatar
robbyriot
Get the $99 one and get that thing running lol
